458 - Help needed ; Frunk lid won't open | FerrariChat
458 Help needed ; Frunk lid won't open
Discussion in '458 Italia/488/F8' started by Snapshift, Jan 3, 2024.
  1. Snapshift
    Snapshift Formula Junior
    898
    Centralia IL
    Lyle D. Pahnke
    Just went to check on car and frunk solenoid suddenly inop. Battery fine. Located emergency release cable and it is stuck, jammed, frozen or corroded. Can't tell which. Totally feels like it's going to snap. Am in the process of having the indy jump the button wires as a trial to check button. If its a fuse and can't get lid open to reach fuses is there any other way to get this thing open other than disassembling the entire car? I don't have a wiring diagram. This could be another looming disaster. Oh the joy. Any ideas appreciated.
  2. LondonParis
    LondonParis Formula Junior
    482
    Houston/London/Paris
    Bill Coates
    Not joking…pull harder on the emergency release. Ferrari emergency mechanisms are notoriously difficult to operate.
    Snapshift likes this.
  3. Viperjoe
    Viperjoe F1 Rookie
    There’s a procedure for re-linking the fob code to the frunk actuator receiver.
    Perhaps someone that knows the exact procedure can chime in. My best recollection is that the procedure involves pressing the frunk opening button on the fob for 3 seconds, 3 times. Then locking and unlocking the passenger doors. Good luck.
  4. James333
    James333 Rookie
    19
    New York
    James W
    This worked for me. I got this from Joe on here (FerrariChat) and put it in my notes for future reference!
    Using one of the two key fobs:
    1) Unlock the doors
    2) Lock the doors
    3) Hold down both the lock and unlock door buttons simultaneously for a slow count to 10
    4) Unlock the luggage compartment using the key fob
    5) Both the key fob the unlock button on the left sill should operate properly at this point
    Snapshift and Viperjoe like this.
  5. DougDish
    DougDish Karting
    215
    Northern NJ
    Doug
    There was a recall on the drunk latch. Be sure this service was done at no charge to you or previous owners.
    Doug
