News
355 Help needed pls on wiring during engine installatio
Discussion in '348/355' started by cactussed, Mar 26, 2020.
  1. cactussed
    cactussed Karting
    Mar 12, 2008
    166
    Chaps
    Just bolted the engine back in and I have a wiring connections I can't remember. Its a 5.2 car.
    There is a black 3 pin female plug just to the right the oil filter and I can't for the life of me recall where it goes?
    Can someone help out pls?
  3. Tubi Sales
    Tubi Sales Karting
    Jul 5, 2019
    164
    PHX
    Hey,
    Anyway you can give us a photo of what your working with? Might give some of us a clearer picture.
  4. cactussed
    cactussed Karting
    Mar 12, 2008
    166
    Not sure I can tonight, but down that side of the V there's the fuel injector plugs, the 2 coolant plugs and the cam phase sensor, all of which are done,
    I just can't for the life of me see / recall where this plug goes.
    For clarity, its not the 3 which cover IAT, Idle control or MAF.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    10,674
    San Carlos, CA
    Mitchell Le
    You should have taken a picture before you took it off. To the right of the oil filters there are 4 or 5 connectors. Show me a picture of it and I'll tell you where it goes.
    Tubi Sales likes this.
  6. To remove this ad click here.
  7. yelcab
    Nov 29, 2001
    10,674
    San Carlos, CA
    Mitchell Le
    #7 yelcab, Mar 26, 2020
    Best Guess: see that T hose 4 inches to its left? Into the hose is the Idle Control Valve. The connector goes to the ICV.
    Better yet, peel back the boot, tell me the colors of the wires and I will confirm what connector that is.
  8. cactussed
    cactussed Karting
    Mar 12, 2008
    166
    It’s not the ICV as that has a seperate one on the same loom spur as the MAF and air temp sensor
  9. johnk...
    johnk... F1 Veteran
    Jun 11, 2004
    8,706
    New England/FL
    By any chance did you disconnect the crank sensor and lay the wire back into the valley?
  10. To remove this ad click here.
  11. Qavion
    Qavion F1 Veteran
    5,234
    Ian Riddell
    Here's a list of 3 pin plugs on the harness:
    Crank sensor (front of engine)
    Knock sensors (L&R)
    Throttle potentiometer
    Idle speed regulator
    Cam sensor
    308 GTB likes this.
  12. yelcab
    Nov 29, 2001
    10,674
    San Carlos, CA
    Mitchell Le
    Peel back the boot, tell me the color of the wires and I will know which one that is.
    Cam sensor has a blue connector
    Throttle position sensor has a grey connector
    Knock sensor has a black connector
    Crank sensor is black but it is no where near that position.
    cactussed, 308 GTB and Qavion like this.
  13. sevminasyan
    sevminasyan Formula 3
    1,131
    Glendale, CA
    Steve
    It goes under the air cleaner
  14. sevminasyan
    1,131
    Glendale, CA
    Steve
  15. taz355
    taz355 F1 Veteran
    Silver Subscribed Owner
    Feb 18, 2008
    5,444
    Indio Ca/ Alberta
    Grant
    Judging from my engine I would guess the crank sensor
    Find the crank sensor on the bank 1 side and follow it back the plug is probably hiding in their somewhere
  16. cactussed
    cactussed Karting
    Mar 12, 2008
    166
    Invaluable, thank you.
    Your post spotted what my tired eyes missed.
    I’d put the throttle position plug onto the crank angle and forgotten about the TPS. All swapped now and hopefully sorted.
    Sodding chassis bolts next
  17. yelcab
    Nov 29, 2001
    10,674
    San Carlos, CA
    Mitchell Le
    That would not end well.
  18. yelcab
    Nov 29, 2001
    10,674
    San Carlos, CA
    Mitchell Le
    You do that first before anything else …
  19. cactussed
    cactussed Karting
    Mar 12, 2008
    166
    They're mostly in, aside from the 2 really awkward ones near the oil tank.
    Meanwhile, my next issue is a snapped coolant union barb (part 157160) which is awkward to reach without dropping the engine. Again.
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,444
    Indio Ca/ Alberta
    Grant
    Let me guesst the barb with the small 3/8 line going back to tank
  21. Qavion
    Qavion F1 Veteran
    5,234
    Ian Riddell
    Interesting. Seems that my 2 year old harness has a few other quirks.
    My colours:
    TPS and knock sensor is black
    IAC is grey
    Cam sensor blue
    I have no CELs and the car runs fine.
  22. cactussed
    cactussed Karting
    Mar 12, 2008
    166
    That's the one.
    I've tapped it to M5 and ordered a replacement barb.
    Fingers crossed.
  23. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,444
    Indio Ca/ Alberta
    Grant
    Broke it on my first engine out
    Tapped and replaced with a brass one for plumbing.
    It’s been through 2 more engine outs and is easily to get at.
    My guess is you will be fine.
    Good luck
  24. 355OXO
    355OXO Karting
    Apr 16, 2006
    161
    Simon
    It connects to the sensor attached to the rubber Y piece i think, can't remember what is called but it is the air sensor i believe.
  25. yelcab
    Nov 29, 2001
    10,674
    San Carlos, CA
    Mitchell Le
    he already said no to the ICV.
  26. 355OXO
    355OXO Karting
    Apr 16, 2006
    161
    Simon
    apologies I did not see this comment earlier in the thread.
