Help needed, pro tips | FerrariChat
Discussion in '308/328' started by Tifosi2011, Sep 13, 2012.
  1. Tifosi2011
    Tifosi2011 Formula Junior
    Apr 3, 2011
    307
    Burnaby, BC Canada
    I was nearing completion of replacing my spark plug wires and luck would have it, the final lead (old one), would not budge from the distributor cap because the set screw if frozen. It tried in vain to remove the set screw but the longer I attack it, the worse the screw is getting. I've applied pb blaster, use a lot of patience, and still no luck. Can anyone offer me a tip on how to remove this screw?
    And for those who have been following my previous threads on an intermittent miss I have on my car, I've traced it to this last spark plug lead. I measured its resistance with an ohm meter and it registered nothing, zero, nada. So please help. I'm so frustrated. Thanks.
  2. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    #2 Sledge4.2, Sep 13, 2012
    Whats the overall condition of the cap? If its old, just replace it, might be less frustrating and if you are going to the pains of getting new wires, might as well complete the task with new caps, rotors, and extenders. Good chance you short is in that fouled set screw.
  3. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,338
    Encino, Ca
    Carl T
    If the screw is corroded, sounds like it is, then you likely need a new cap. Try sanding the top of the screw with 600 grit paper and see if that works.
    New caps are mostly repros, IIRC, and don't come cheap. Need to change both after all. Last I looked $500 a pair???
  4. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    $200 a piece at AW Auto Parts
  5. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    Superformance UK = $137.70 each for caps
  6. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    thats a great price, good post.
  7. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,327
    Montana
    Kim
    I've got a set of new caps (84 QV Euro) that I purchased from Superformance last month, decided to use my OEM caps after Dave Helms tested them and said they were fine. I'd let them go for $200.00 for the set + UPS if your interested drop me a PM and I'll get them out tomorrow. Kim
  8. Tifosi2011
    Apr 3, 2011
    307
    Burnaby, BC Canada
    I have just sent out a PM to you.
