Help needed removing 308GTB lower transfer gear bearing | FerrariChat
Discussion in 'Technical Q&A' started by paul 308, May 2, 2011.
  1. paul 308
    paul 308 Karting
    Jan 13, 2004
    110
    Guildford, Surrey UK
    Paul Deslandes
    In spite of my best endeavours, the lower bearing is stuck on the gearbox input shaft and won't budge or 'walk-off' as per Birdman's procedure.. Unfortunately the bearing fouls on the bellhousing casing which cannot be removed with the bearing still in situ so has to be removed first along with a circlip. I've managed to jack it along the shaft a little way but there's nothing behind it push it along as far as I can see and no means of gripping it to give it a pull.
    Short of destroying the cage holding the rollers so I can get a purchase on the bearing inner sleeve to pull it off, and even that will not be easy, can anyone offer a better, less destructive (and expensive) way of removing it? I've tried local heat to expand the sleeve but so far this hasn't helped. I've seen some fancy bearing pullers advertised at huge prices but I'm not convinced that even they would do the job.
  2. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    #2 350HPMondial, May 5, 2011
    Push the bearing back in,, sand that shaft with emery cloth, clean it good,, don't use any heat around the New spray cleaners ( aka break clean) ,, then lube that shaft with engine oil,, try again.
    Breakclean (fluorocarbon) + heat = nerve gas
    Oh,, and check that the spline isn't expanded,,, if it is, file off the burr ,,, carefully.
  3. paul 308
    paul 308 Karting
    Jan 13, 2004
    110
    Paul Deslandes
    Thanks. In the end, after sitting there looking at it like lemon for several hours, I made a small puller with small flag shaped fingers that got hold of the inner track in between the rollers and it came off very easily. Just needed an even pull, rather than force.
    It all went back together a lot more easily than it came apart and is working fine now. The dry sump scavenge pipe, that runs across the front of the engine, had to be fully undone at the pump end to enable the bracket to clear the bellhousing front 'triangle' and needed a 36mm open ended wrench.
    Thanks for the tip re brake cleaner and heat. I've often thought that it must be pretty volatile stuff. Not that volatile though.
    Paul
  4. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    Yep, Phosgene.
    I was told by a welding instructor that it wasn't just heat but heat plus ARGON (used in TIG/MIG) that was needed to synthesize Phosgene from the older break clean compounds. Thats why here in the Nanny State (CA) they only sell non-chlorinated brake cleaners now. Not sure about other places.
    http://www.brewracingframes.com/id75.htm
    Rick
  5. tazandjan
    39,164
    Interesting how things evolve. When teflon was first introduced as a bearing material, it also produced phosgene gas when heated. The teflon we use on frying pans has obviously evolved a bit, too.
    Taz
    Terry Phillips
  6. Ehamilton
    Ehamilton F1 Rookie
    2,634
    Durham, NC; USA
    Eric Hamilton
    This is often a necessary step. A cold beer makes it easier.
