Help needed separating Tie Rod ends | FerrariChat
Discussion in '348/355' started by Badabing!, Apr 12, 2015.
  1. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    731
    NYC
    I am working on changing the steering rack boots.
    I am putting together a detailed DIY with lots of pics.
    However, I am stuck because I can't get the outer tie rod to separate from the spindle. Anyone got a tip?
    I tried one of those fork style separators from harbor freight, as well as putting the nut back on and hitting it with a dead blow. No joy so far.
  2. SoCal1
    SoCal1 F1 Veteran Owner Silver Subscribed
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Hit the side with a big hammer, it will pop it right out off the taper
  3. 2NA
    2NA F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
  4. INTMD8
    INTMD8 F1 Veteran Owner Silver Subscribed
    Jun 10, 2007
    6,791
    Lake Villa IL
    Yes but hit the spindle, not the tie rod :)
  5. emac
    emac Formula Junior Silver Subscribed
    Sep 14, 2014
    851
    upstate SC
    ernest
    I have not removed the tie rod on the 355, but I do both things suggested when removing a tie rod. . I put a tie rod remover on the tie rod (leaving the nut on loose), add some pressure, and hit the the spindle with a hammer, pops it right off on the second or third tap.
  6. Badabing!
    Mar 30, 2014
    731
    NYC
    I tried hitting it but on jack stands I really can't get a good swing at it. I should have bought the tool 2NA suggested from the start.
    Oh well, lesson learned. Always buy the best/right tool for the job.
    There's always next Sunday.
    Thanks guys.
  7. emac
    Sep 14, 2014
    851
    upstate SC
    ernest
    Try turning the wheel all the way so the tie tod has some tension. Then wack the outside of the tie rod holder. It should pop off.
  8. Badabing!
    Mar 30, 2014
    731
    NYC
    anyone know the torque spec for tightening the nuts once they are ready to go back together?
    I looked in the WSM but the descriptions dont make sense to me
    EDIT: My good man DR dropped the knowledge on me. 63 Nm (~ 46 ft/lb) as per page F53 of the WSM.
  9. Badabing!
    Mar 30, 2014
    731
    NYC
    I'm hoping to get back to this project today (3 weeks later)
    Is there any sort of grease or lubrication I should be applying to the rod(s) that slide in and out of the steering rack cylinder?
    I tried googling in general but get conflicting info. I bought some multi purpose lithium grease jic.
  10. GTSNJ
    GTSNJ Formula Junior
    Jan 18, 2015
    478
    Those seals are made to keep dirt out . I never lubed the outer section because then dirt could stick to the grease...and then tear up the seal in my opinion.
  11. Badabing!
    Mar 30, 2014
    731
    NYC
    So I got my ass kicked today.
    This car...many things are mechanically simple but mother@$@! impossible to do.
    I started at 3 pm. Car was already jacked with the wheels off and tie rod nut undone.
    I popped the joint with the harbor freight version of the tool 2NA posted. Spun the outer tie rod off and I was ready to remove the old boot. Should be easy right?
    Wrong!
    From 3:30 to just about now I struggled to get the old boot off. The main difficulty was opening the retaining clip on the rack. I did eventually get it open and removed the old boot.
    Getting the new boot on? Impossible with the rack in the car (at least for me). I struggled for hours. Eventually I got the large boot opening over the rack but I could not re-secure the clip.
    I repeatedly jammed my hand in that tight space and tried to maneuver. My hand is literally battered and bruised. I'll be surprised if my hand doesn't look like a blue balloon tomorrow.
    I tried to make the stooges proud today. I failed.
    Someone tell me there is a trick. I don't want to take this to the shop. This should be simple.
  12. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,618
    San Carlos, CA
    Mitchell Le
    There is no trick. The rack comes off the car.
  13. Badabing!
    Mar 30, 2014
    731
    NYC
    Finally did it. Definitely stooge style. Passenger side took 5 hours last sun plus 1.5 hours today.
    Once I developed my technique the driver side took 1.5 hours from start to finish.
    Detailed DIY to come.
  14. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
  15. Badabing!
    Mar 30, 2014
    731
    NYC
    I have seen this thread and it is exactly why I tried to do it without removing the rack.
    All I needed to do was replace the torn bellows. The rack itself was not leaking (knock on wood)
    It took me forever, and I learned alot, including that some jobs are worth every cent a professional charges.
  16. yelcab
    Nov 29, 2001
    13,618
    San Carlos, CA
    Mitchell Le
    So will you post your technique for installing the bellows without removing the rack?
  17. SoCal1
    Jun 14, 2011
    8,630
    Tim Dee
    I cant tell you how many of those I broke over the years
  18. Rifledriver
    37,184
    I have a Stahlwille. I have tried real hard to break it without success but it doesn't always get the end loose either. My big hammer and a big drift on the other hand have a 100% success rate.
  19. SoCal1
    Jun 14, 2011
    8,630
    Tim Dee
    Dude, drift? You need to take Karate classes LOL For a swift swack
    I have a sledge hammer I cut the handle down to 10 inches. One pop maby 2 for a truck ball joint
  20. Badabing!
    Mar 30, 2014
    731
    NYC
    Yes, that was the plan from the start. Will do in a separate thread why I have some time.
