help needed with 550 suspension settings | FerrariChat
Discussion in '456/550/575' started by stephens, Jun 19, 2004.
  1. stephens
    stephens F1 Rookie Lifetime Rossa
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    I posted this in the tech section as well, hoping for a response.
    Does anyone have any info on alignment settings for the 550? Also info on the ratios for movement of the shock spring collars and their effect on ride height would be great. Today I discovered that my car sits 1/2" higher back and front on the passenger side, so I want to sort that out and at the same time get the suspension re-aligned.
  2. bobafett
    bobafett F1 Veteran
    Sep 28, 2002
    9,193
    Glad to see you got it sorted out mostly (tech section).
    My alignment was set when I last did a tire change. Will pull the numbers today.
    --Dan
  3. stephens
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    Thanks Dan, appreciate the help.
