help on buying a 355 | FerrariChat
Discussion in '348/355' started by arnonkraft, Oct 8, 2013.
  1. arnonkraft
    arnonkraft Rookie
    Oct 8, 2013
    8
    I am looking to buy my first Ferrari. I was originally looking at a few 308's but now found a nice 1995 F355 Berlinetta.
    Would appreciate tips and inputs with regards to:
    - maintenance costs
    - market value - what is a fair price
    - market value - has this model (similar to the 308) reached the bottom of the price curve or should I expect a decline in value still?
    thanks!
  2. FullChat
    FullChat Formula Junior
    Jan 1, 2007
    339
    San Antonio, Texas
    Search is your friend.
    These topics are covered continuously.
  3. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Summary:
    1. Budget $5500 every 5 years for major and $1000 per year for fluids maintenance. Keep some extra cash for unknowns. 355's have several issue itmes that can get expensive unless you do your due dilligence up front.
    2. $50K should buy you something decent in the 1995 year. Less if it needs work. More if it is an outstanding example.
    3. Values will hold on this model and increase except for the later years and more expensive priced ones which will likely drop. The 1995 B's will increase soon because of the cult following these models so get one soon if that's what you want.
    Use search for more detail.
  4. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    After 9 years of 355 ownership I must say that this is the most concise and accurate summary that I have seen. Every word counts. Perfectly summed up.
  5. phrogs
    phrogs F1 Veteran
    7,359
    Kzoo Michigan
    How in the hell are your fluids costing you $1000 a year? Unless you have it done at the dealer. DAMN!
    If you do your own work you can save substantially on the costs of maintenance.
  6. Rob'Z
    Rob'Z Formula 3
    Mar 29, 2008
    1,024
    Tucson,AZ
    Robert
    An oil change with filter will cost ~$140 if you do your own work. I have a receipt from a previous owner for an oil change, from memory I want to say it was $350+. Two of those a year (if you drive it enough) and that's $700. Add in flushing the brakes/coolant and changing the trans fluid and you could easily hit $1000.
    Doing your own work will save a substantial amount of money. I personally would not have bought my F355 if I was scared of wrenches. No way would I be comfortable spending some of the figures I see thrown around here.
    Rob
  7. ronrob
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    Vince said fluid maintenance - there are fluids other than engine oil.................think brake fluid as well.
    His advice to the OP was clearly based on paying for the work; during my ownership, my car has never seen the inside of a workshop either.
  8. mike_747
    mike_747 Formula Junior
    Dec 15, 2008
    794
    Seattle
    As for price, $55k would buy you a museum piece with under 8,000 miles. Ignore the prices you see on Ebay, cars are not selling at those prices ($60K and up) in general. You should be able to find a very nice "driver' with a recent (less than 2 years) major service for $45-$48K. don't forget the PPI, its critical.
  9. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Not a chance - more like $70K. Show me a museum piece w/ less than 8K miles for $55K and I'll buy it right now...
  10. phrogs
    phrogs F1 Veteran
    7,359
    Kzoo Michigan
    #10 phrogs, Oct 9, 2013
    Someone liked getting robbed! $350 for engine oil change haha
    I'm with you I do it all myself, I wouldn't have the cars I have if i had to pay a shop to do jobs especially fluid changes.
    Trans, brakes, coolant those can be pushed beyond a year lets say every two, unless your racing. It also depends on what oils fluids your buying.
    You can get deals on oil of course and do you guys really have to have the Ferrari filter?
  11. tamf328
    tamf328 Formula Junior
    Mar 9, 2005
    477
    50K might buy you a nice 95 but everything I looked at was more than that.
    may be mileage and color make a difference as well a yr. this was about 1 1/2 ago.
  12. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    You guys are funny. Annuals will run you over $1K a year if your have a good independent do it. If you do it yourself, easily within everyone's capabilities, it's less.
    Filter = $45
    Oil = $50-$100 depending on how fussy you are
    Trans oil = $35
    Coolant = $40 if you use the BMW stuff
    Brake fluid = $40
    Air filter = $20 again depending on your preference
    You can get away with coolant and brake fluids every 2 years.
    Around $300 in parts and fluids. The rest is labor. Add a bit for 355 Spiders and replacing their hydraulic fluid every other year.
  13. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
  14. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,185
    So. CA & NV
    Peter
  15. lauris
    lauris Formula Junior
    Jul 27, 2005
    281
    Glasgow
    Scott Laurie
    I think this topic degenerated somewhat off topic.
    In UK, I would allow £1000 a year for service and about £2k+ every third year for belts. sometimes more, sometimes less, things go like radiators, clutches, aircon, steeting pumps, shocks, etc, just like any normal car,
    find a good independent that can service your car at a reasonable cost and someone that's known to others that have 355's and you should be fine.
    95 cars have their own issues in terms of valve wear, search on here and you will find the posts, but I would imagine all cars have been repaired or don't suffer it by now.
    have whatever car you are buying inspected by a main dealer or an independent, for peace of mind or to use what they find as a bargaining tool to agree a purchase price.
    prices have been fairly stable for about last 10 years on 355's in the UK, here a good low mileage (ie. less than 30k miles) will cost about £40k,
    avoid F1 boxes, they are just simply more expensive to repair and less desirable, they suit some, but if you watch the market they sell less well.
    I think 355's have bottomed out on price and at some point (who knows when) start to appreciate, 308's have certainly doubled in price in the UK in the last 10 year and as Ferrari continue to put their entry level prices up and up, then it helps hold the market price on older cars. Will they be the next dino, probably, but that could be 20 years away,
    The 355 is a stunning car to look at and drive, it has one of the best sounds ever from an engine, you will love it !,
    regards
    Scott.
    Glasgow,
  16. CANDREAM
    CANDREAM Canada
    Nov 13, 2009
    407
    Burlington, Ontario
    Sadi
    Both cars are different animals...or horses :)....drive both.
    if you will lose sleep about cost/panic if you get a CEL on your dash, you probably should look at another car......honest feedback.
    You might find a perfect unit and pay slightly higher...but again, things can start wearing out as you drive it and will need fixing. Those cars like maintenance......look for one with history and an owner who cared about the car .....at least this will allow you to enjoy it before you start spending on it. This is a personal choice though as some owners prefer to do the repairs.
    It does help if you wrench on your car...primarily to bond with it...yes and save some money....but parts are not cheap .....
    What is the satisfaction of driving a Ferrari and belonging to this passionate culture worth to you ?
    Think with the heart :)
  17. F355Bvc
    F355Bvc Formula 3
    Dec 4, 2003
    1,734
    Lawrenceville. GA
    Vince Canipelli
    I sent you a PM, about my F355, For Sale !!
  18. lonestarrpm
    lonestarrpm Karting
    Aug 26, 2013
    57
    Austin, Texas
    Lone Star RPM. LLC
    You'll have to pay $55.1k as I'll bump it at least $50 :)
  19. arnonkraft
    arnonkraft Rookie
    Oct 8, 2013
    8
  20. mike_747
    Dec 15, 2008
    794
    Seattle
    the second car has high mileage (for a Ferrari) and no mention of a recent (within 3 years) major belt service. It has had some work done, to fix failures but still needs the $7k+ belt service. when you price this in, the first car is a better deal, hands down.
  21. 355dreamer
    355dreamer F1 World Champ
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    So much misinformation here...
  22. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    It's more like the higher priced car is way over priced, particularly for a private sale. Last spring a similar very similar car (yellow 95 GTB) with fresh major went for around $50k or under from a dealer. I forget the exact mileage but it was closer to 20k. You really need to see records and when the last major was. If the 46k mile car had a recent major (within a year) and no issues and a good PPI, I think the ask is reasonable. If the 26k miles car is the same, I walk away at anything over $52k, and that's only because it has the carbon fiber seats.
  23. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    CF seats and Hyperflows and Tubi and headers. What else does it have that the oher one doesn't? Still high but not too far off IMO.
  24. arnonkraft
    arnonkraft Rookie
    Oct 8, 2013
    8
    see your point. what if the belts have been replaced in that service they mention? does that change the picture?
  25. arnonkraft
    arnonkraft Rookie
    Oct 8, 2013
    8
    what is the lower mileage car had the last belts replaced 2 yrs ago - is it still a good deal?
