Help on locating | FerrariChat
Help on locating
Discussion in 'Boxers/TR/M' started by Minixl, May 26, 2014.
  1. Minixl
    Minixl Rookie
    Nov 2, 2003
    3
    Ponte Vedra Beach, F
    Larry Minix
    #1 Minixl, May 26, 2014
    Greetings on Memorial Day,
    I am in the process of renovating the underbody of my 93 512TR, now I need to locate specialty nuts & bolts that either are missing or broken, attached is a photo of the nuts that I need, can anyone make a suggestion. I have the part number, the problem this is a swiss car and other TR models seem to have a different configuration.
    Any suggestion's would be appreciated.
    Thank you,
    Larry
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,468
    romano schwabel
    even you are here a member since more than 10 years and this is your 2nd post it would be good to introduce yourself a little please
    those picture quality is not so good. could you make better ones please?
    what are the original numbers?
  3. Minixl
    Minixl Rookie
    Nov 2, 2003
    3
    Larry Minix
    Hi,
    Sorry traveling for several weeks. Attached are some new photos of the nuts that I need, in the manual parts number is listed as:
    #1464848490
    It is basically a nut with an extra part added with 2 bendable wings to hold it into the "Front motor cover" it requires 3 each.
    The car is a 93 model has 12,400 miles, I purchased in Switzerland 14 years ago. Hopefully the photos are of a better quality this time.
    Thanks, Larry
  4. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    These are common to lots of cars...
    Phil
  5. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    Larry I think you added two extra numbers in the PN above. I think you mean PN 14648490 (#45 in this diagram Ferrari 512TR Parts : Table 107 - CARPET FOR LUGGAGE COMPARTMENT AND INSULATION PANELS). I would try Ricambi, T. Rutland and definitely try FerrParts, they have a lot of original hardware in stock. Or like Phil said, maybe another application uses the same type. It looks like you could fabricate the cage fairly easily with spring steel so it would snap in and retain the square nut. This is similar: Ferrari Testarossa 328 348 355 456 512TR 6mm Captive Nut | eBay though may be wrong size (this is M6). Good luck with your search, I hope you can come up with something that will work.
  6. teveo
    teveo Formula Junior
    Oct 1, 2005
    403
    Norway
    Trond Vidar
