Help over heat f430 | FerrariChat
Help over heat f430
Discussion in '360/430' started by rxzoco, Mar 19, 2017.
  1. rxzoco
    rxzoco Rookie
    Jul 1, 2014
    15
    #1 rxzoco, Mar 19, 2017
    Hi I haven't drove it for about a week 2007 f430
    I let it idle for about 18 minutes because haven't started it
    And the coolant temps are over 220 f what can the issue be please help thanks
    No check engine lights or anything
  2. Edgar Diaz
    Edgar Diaz Karting
    Sep 13, 2014
    198
    Alabama
    Edgar Diaz
    Can you hear radiator fans coming on? They should come on when the coolant gets hot. Maybe a fuse is blown or a bad relay. That would be the first things I would look for.
  3. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    Did you drive it? If so did the temps come down. I would not idle my car for that long. 5 mins max. You really want air flow through the radiators. As stated though, the fans should have come on.
  4. rxzoco
    rxzoco Rookie
    Jul 1, 2014
    15
    Thanks. For the response I really didn't have time to drive it I parked it so busy today but so you know what temp the fans should kick in ?
  5. 338Lapua
    338Lapua Formula Junior
    Sep 5, 2015
    835
    Michigan
    Tony
    Fans should kick on around 190-200F (the mark just before 210) if you are sitting idling.
  6. djempire
    djempire Formula Junior
    Apr 30, 2012
    613
    Toronto
    Serf
    +1 on the fans but airflow will assist in cooling. Check fuse/relay, they are know to pop.
