Help please-355 belt drive pulley bearings | FerrariChat
Discussion in 'Technical Q&A' started by charles dyer, Nov 5, 2010.
  1. charles dyer
    charles dyer Rookie
    Mar 1, 2004
    18
    I am doing a major service on a 95 355 with 75K miles. Should I replace the cam belt drive pulley bearings in the front cover and the front of block. On my 308 at this mileage it was highly recommended. Does anyone know if these bearings are failing on 355's ?
  2. junglistluder
    junglistluder F1 Rookie
    Mar 23, 2007
    3,617
    VA
    Brendan
    sounds like you're asking if you should replace the timing belt tensioner bearings.... YES! Especially with that mileage. I would also replace the accessory belt tensioner bearing too.
  3. jeffdavison
    jeffdavison F1 Rookie
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    Hill tensioner bearings from Daniel @ Ricambi.....
    end of discussion
    JD
  4. Rifledriver
    37,090
    No, he is asking about the drive bearings. A very different part. He even described their location.
    At 75k miles I think it would be a very good idea.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,556
    San Carlos, CA
    Mitchell Le
    #5 yelcab, Nov 5, 2010
  6. 335s
    335s Formula Junior
    Jan 17, 2007
    870
    SF Bay Area
    T. Monma
    The tool you seek is called; "a blind hole bearing puller" with pin studs for caged rollers
