Help please-355 belt drive pulley bearings | FerrariChat
Discussion in '348/355' started by charles dyer, Nov 5, 2010.
  1. charles dyer
    charles dyer Rookie
    Mar 1, 2004
    18
    I am doing a major service on a 95 355 with 75K miles. Should I replace the cam belt drive pulley bearings in the front cover and front of block? On my 308 at this mileage it was highly recommended. Does anyone know if these bearings have been failing on 355's ?
  2. Sandy Eggo
    Sandy Eggo F1 Rookie
    3,636
    Encinitas, CA
    Rick
    I believe it's considered a standard procedure for a major. Get the Hill Engineering bearings...should be $424 for a pair of them.
  3. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    Its false economy not to mate, do it.
    Replace with Hills uprated units.
  4. jeffdavison
    jeffdavison F1 Rookie
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    Hill Engineering tensioner bearings from Daniel @ Ricambi....
    End of discussion
    JD
  5. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Absolutely YES...you will have to use an OE Ferrari part for the ones in the front engine cover...Hill does not make them.
    Be sure also to get the seal/o-ring for these bearings...
  6. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    What bearings are we talking about? I thought it was about tensioners.
  7. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,727
    He is talking about the bearings that support the belt drives down near the crankshaft nose.
