My instroment cluser is not lighting up is there a fix.
If it is all lights it sounds like a blown fuse to me. Have you checked and tested the fuses that handle your dash lights? Check your owners manual. It should tell you the location of the fuse panel and the fuse one which the dash lights are fused.
also, can't remember if the guage lights on the 575 are on a rheostat but I would guess they are...check the manual for location and make sure that it didn't just somehow get dimmed down to the point where the light appear to be off. Best of luck.
Nicky- Instrument panel lighting is controlled by pushing the left hand multi-function display scroll button for over two seconds and then cycling through the four options until you get to instrument brightness adjustment. The right hand button is then used to adjust the lighting. 0 is minimum and 30 is maximum. Taz Terry Phillips
This chet is the best. I HAVE CHECKED THE FUZES THEY ARE ALL GOOD I HAVE AJUSTED THE LIGHT TO 30 AM NOT ABLE TO GET LIGHTS ON THE INSTURMENTS ONLY THE NEEDLES ARE LIT AND THE WARNING SIGN AND THE GEAR FIRST SECOND THIRD AND SO ON.
It sound like the failures on the 360s. Those require removal of the instrument cluster and either replacement of it or repair by one of a few private parties who repair them. Ferrari offers no such service. I have not seen a 575 do that yet but it sounds the same.
