help please-horn not working | FerrariChat
Discussion in '206/246' started by scotgm, May 13, 2007.
  1. scotgm
    scotgm Rookie
    Mar 12, 2005
    16
    Hi all-horn suddenly quit over the winter. Fuse is ok, opened "blower" and it moves-no corrosion. Horn button works, as the relay makes a clicking noise. Is it the relay? If so, which one is the horn relay? VIN 4464. Suggestions most appreciated-Scot
  2. John Corbani
    John Corbani Formula 3
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    See if wires to compressor are on and not corroded. Had to clean 2 times in past 20 years. WD-40 and a little pinch of the push-on springs did the job. If relay clicks, horn button circuit is fine. A simple voltmeter test will find the problem. Just take off the belly panel between the front wheels and you can get at everything.
  3. scotgm
    scotgm Rookie
    Mar 12, 2005
    16
    As it turns out, the compressor was partially frozen up-got it loose and now compressor works. But there is a lot of Liquid Wrench in there and it sounds like a Schwinn! I think time and honking will improve it-thanks-Scot
  4. Herb Kirshrot
    Herb Kirshrot Rookie
    Feb 12, 2007
    24
    Portland, Oregon
    you can replace the compressor for less than $75.00. Fiamme still makes the same horn and compressor, just w/o the oil fill and now all silver color.
