Help please on fualt code P1122 | FerrariChat
Discussion in '360/430' started by Stalyhill, Mar 29, 2013.
  1. Stalyhill
    Stalyhill Rookie
    Feb 5, 2013
    8
    My engine warning light comes on after re starting the car cold or hot after reset the ecu
    Basically if i turn the battery on and start the car its fine
    But if then i turn the engine off and back on either after 10 seconds or 1 hour
    The engine warning light goes off and comes back on and once its on it won't
    Go off unless the power from battery is turned off basically re setting the fault code
    Now the fault relates to a cat sensor or 02 sensor in the back section of the
    Exhaust system but here may be the issue the car has a sports exhaust system fitted
    Could this be where the problem lies?
    The system is a capristo and was fitted to the car when I got it
    Which was only a few weeks ago the guy did tell me it was nothing to worry about and it was
    Down to the exhaust.
    Any help would be appreciated before I take it to the garage.
    Thanks.
  2. 458Italia
    458Italia Karting
    Jul 30, 2009
    66
    P1122 should be 02 Sensor Heater Circuit (@ Bank 2), check your 02 sensors.
  3. 993man
    993man Formula Junior
    878
    New Zealand
    Graham
    I have the exact same issue. The Ferrari guy told me not to worry about it, so I don't.
    Like you, when I reset the system it goes out but always comes back on when it warms up.
    I reset the system with my OBD scanner every now and then as well.
    One day we will get it sorted, as will you.
  4. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    No annual smog check required to register the car ?
