Help Please - Passenger Door Not Opening | FerrariChat
Discussion in 'Mondial' started by Bear Mondial, Aug 22, 2023.
  1. Bear Mondial
    Bear Mondial Rookie
    Jun 12, 2022
    8
    Oliver Hunt
    On the weekend my wife, my 19 month old boy and I went out in the mondial - the family mans Ferrari.
    Unfortunately when we got home the passenger door wouldn't open, either from inside or outside. My 8.5 month pregnant wife had to climb out the drivers side (not impressed) and I had to get my boy out of his child seat through the window. Neither of which is helping to convince my wife that going out as a family in the Mondial is a good idea.
    How can i get the door open to allow me to remove the door card and find the problem?
    Thanks in advance.
  2. moysiuan
    moysiuan F1 Rookie
    4,174
    Canada
    This is a video showing removal of the door panel, and some of the insides with the locking mechanism.
    You might need to "slim jim" the door lock, and knowing what is inside there might be helpful to do that. I don't think the door panel will remove with the door close, you need to remove that small screw to get the second from the top trim paoff, the rest would be removalable with the door closed. Maybe you can get some long nose pliers and try to remove that key little screw with the door closed?
    Sounds like you have a broken cable, or the plasticpiece that hold the cable to the lock broke.
  3. afterburner
    afterburner F1 Rookie
    3,468
    Switzerland
    Urs STEMMLER
    Is the door locked or unlocked - can you move the outer/inner doorhandles to their open position or not?
  4. Mondi Cab
    Mondi Cab Karting
    Oct 9, 2019
    170
    EU
    J.Schulz
  5. Alden
    Alden F1 Rookie
    3,563
    Central Florida
    When you say "passenger side," that means something different in the UK and the USA, it helps to tell us where you are. Although the door mechanisms are identical, I'm just asking people to give us more info about their specific location model so we can help you better!
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    Long time since i had a mondial but i seem to remember you can remove the black plastic surround, around the internal handle, will give you access to the opening linkage
