Help please: Weird exhaust burp sound around 5,000 RPM | FerrariChat
Discussion in '360/430' started by whatheheck, Mar 12, 2015.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I went for a drive today and started getting this constant loud burping sound on my mufflers on 2nd gear at around 5,000 RPM.
    Car runs fine. Exhaust sound is normal below 5,000 RPM and higher than 7,000 RPM
    Anyone else experienced the same issue?
    What was the culprit and what did you do to fix the issue?
    My car is a 2003 360 F1 Spider with 21,000 miles. I have a non valved Tubi exhaust installed.
    Car ran perfectly and exhaust sound was normal before today.
    Any help would be greatly appreciated.
    Thanks in advance.
    Dan
  2. Perkins
    Perkins Formula Junior
    Dec 22, 2013
    702
    Sacramento
    Rick
    When you say "at around 5,000 RPM," are you talking about holding steady revs at 5k, accelerating or decelerating? Does it sound like the overrun sound?
  3. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Yes the burping sound starts at ~ 5,000 RPM and if I hold it steady at 5,000 RPM the burp sound continues. Once I accelerate to about 7,000 RPM the burping sound goes away. Really weird.
    The burping sound is like an exhaust valve being opened but I have no valves in my Tubi exhaust.
    I will try and record the sound this weekend and post it here.
    Thanks for chiming in.
    Dan
  4. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    The burping sound once it starts is like an exhaust valve being wide opened but I have no valves on my Tubi exhaust.
    Dan
  5. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I want to provide an update to this thread of mine.
    The fault code thrown was accurate. Pre-Cat sensor was bad.
    Removed and replaced both pre cat sensors and this issue went away.
    Dan
  6. BSU
    BSU Formula 3
    Mar 30, 2008
    1,012
    TX
    Glad you worked it out.
