HELP! Psychotic headlight... | FerrariChat
Discussion in '308/328' started by Casino Square, Feb 14, 2017.
  1. Casino Square
    Casino Square Formula 3
    1,728
    Hong Kong / USA
    Andrew
    Need some tech advice (looked on stickies but couldn't find a reference). When I turn on my headlights (or turn them off), the left headlight does a good impression of a yo-yo, continually moving up and down. Sometimes it stops on it's own, other times I have to physically stop it moving by hand. Any ideas on how to correct his problem? Thanks in advance.
  2. dflett
    dflett Formula 3
    1,632
    NY
    David
    You could try changing the LH and RH relays for the headlight motors to see if the problem swaps side. If it does, relay is the issue, if not, relay is not the issue. If not relay then perhaps its the motor or linkage but I'd suspect relay first.
  3. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    432
    Midlands,uk
    Paul
    I had this happen on my 328 (not 308) after it went for a service, the mechanic managed to knock off the light stork end and put it back on 90 degrees in the wrong position, refitted correctly and back to normal.
    Good luck
  4. Casino Square
    1,728
    Hong Kong / USA
    Andrew
    Thanks guys, will look at both. Appreciated.
  5. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,223
    Gold Coast, Aust.
    Patrick
    Check the motor mounting bolt - if it's loose, the motor can move just enough so the armature contacts the live track and around we go again! Ask me how I know :)
  6. Casino Square
    1,728
    Hong Kong / USA
    Andrew
    Thanks for the heads-up mate. I will be checking all the mentioned scenarios tomorrow. Appreciate all of you taking the time to reply. Cheers.
  7. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,203
    Norfolk - UK
    Tony
    Its a common problem on the 308, my car did this and I eventually traced the problem to worn / loose drive linkage/s which in turn messed up the settings.
    Think of the motor turning in one direction only which switches on / off at 12 o clock (headlight up) and 6 o clock (headlight down) in other words 180 degrees opposing. If it goes past these positions by a small margin say 12.15 then it rotates again to the next on / off position which will be out because off the fixed linkage, hence the headlight continually pops up and down.
    check the linkages very very carefully, strip them down and make sure they are all good especially the rose joints, any slack will cause you a headache in setting them up.
    Adjust the linkages accordingly, its a bit fiddly but is easily figured out once you start. You also have bump stops which need adjusting to get the bodywork level once again
    EXTREME CAUTION - Mind your fingers
  8. Casino Square
    1,728
    Hong Kong / USA
    Andrew
    Thanks Tony. Appreciate the help from everyone. Cheers.
  9. Ferraridoc
    Jun 20, 2012
    17,223
    Gold Coast, Aust.
    Patrick
    Actually, disconnect the battery
  10. Casino Square
    1,728
    Hong Kong / USA
    Andrew
    thanks again....need those fingers :)
  11. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,203
    Norfolk - UK
    Tony
    Actually it's easier to pull the plug on the motor, but at some point you need power on to adjust.
  12. sm1
    sm1 Rookie
    Oct 10, 2013
    3
    #12 sm1, Mar 9, 2017
    Traced it down on my 308 to a blown diode on the headlight motor per: http://www.ferrarichat.com/forum/137419146-post3.html
    However, under the rubber casing, the whole motor and electricals are covered in some thick, rhino-liner like material. Anybody have any tips on out to cut/melt/dissolve through this stuff? Would hate to replace the whole motor for a component that's literally less than a dollar.
    Thanks for any suggestions!
