Help!! Radiator Leaking Part 2 | FerrariChat
Discussion in '308/328' started by Formula Uno, Feb 22, 2010.
  1. Formula Uno
    Formula Uno F1 Veteran
    Oct 8, 2008
    6,659
    New York City
    I Just wanted to let you guys know that (with the help I recieved here) I removed my radiator today in approx. 1.5 hours with ABSOLUTELY NO PROBLEMS AT ALL!! Thanks so much to those of you who replied to my post.
    I did not remove my lower valence, but I did remove the hood. The only mess was that coolant went everywhere, and the hose clamps were rusted and a ***** to remove.
    I'm going to try to match up the hoses at NAPA.
    My mechanic quoted me 7 hours labor for the job, but I can't see that it will take me even half that unless I run into trouble putting it back in...makes you think about how much time they really spend on your car.
    Money aside, I got alot of satisfaction doing the job myself.
    Frank
  2. BigTex
    79,380
    Houston, Texas
    Bubba
    It's just a car!
    Good to hear!
    Last time my car was on a lift the shop pointed out rusting (near failure) hose clamps...."These are original."
    From 1976!!!!
  3. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
    Good job! As BigTex says, it's just a car. Nothing overly magical about the cooling system.
    It can make quite the mess. Make sure you put in that other T (or petcock) and the next time you need to drain the system, you probably won't make a mess at all.
  4. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    SWEEEEEEEEEEEEET!!!!!!
    Love it. I think the hours quote is accurate ;) you're just better than a mechanic already, you are an attentive caring owner.
