Help: Removal of 308 GTS seats | FerrariChat
Discussion in 'Technical Q&A' started by Quasimotor, Feb 3, 2004.
  1. Quasimotor
    Quasimotor Formula Junior
    Jan 4, 2004
    333
    Yonkers, NY
    George Avgerakis
    How do you remove the seats from a 308 GTS. An old thread said to remove the front 6mm allen nuts, then slide the seat forward and remove the rear nuts. Nope. The rear nuts do not expose themselves. It seems I have the seat as far forward as it will go. Am I doing something wrong? I wanna get the Leatherique working.
    pegasus500 likes this.
  2. ROGER
    ROGER Karting
    Feb 9, 2002
    131
    Lake Havasu City, Az
    Roger Blakeman
    Quasi--
    The bolts are there, you just don't have the seat forward far enough to gain access to them. It does take some force to get the seat far enough forward.
    Roger B.
    Mike Morrissey likes this.
  3. Gianluca
    Gianluca Formula Junior
    May 6, 2003
    349
    Centreville, Virgini
    Gianluca Chegai
    That is the way I removed them from my '81 GTSi.
    Try to forward-tilt the seat to see if it gives a bit more room to access the Allen screw. Also the seat may be a little reluctant to go so far ahead. I would try to shove it forward with, some momentum, starting all the way from the back.
  4. Quasimotor
    Jan 4, 2004
    333
    Yonkers, NY
    George Avgerakis
    Okay, Let me go back out there and give it a bigger shove. Stand by.
  5. delaney
    delaney Formula Junior
    Nov 8, 2003
    711
    St Petersburg, FL
    PETER DELANEY
    Sounds a bit crazy, but if you sit in the seat and use your body momentum to force it forward it may help. But I agree ... the bolts ARE there..but the seat HAS to be as far forward as it goes ... probably much farther forward than its ever been.... hence the stiffness.
    Foxie likes this.
  6. Quasimotor
    Jan 4, 2004
    333
    Yonkers, NY
    George Avgerakis
    Yeah, baby. That worked! Now would someone please tell me how I get out of the car and how to get my testicles out from under my tie?
    NYC Fred and Mike Morrissey like this.
  7. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    You'll probably get no help with the balls-under-tie problem. Most of us ditch the tie during "work on the f-car" mode! :) j/k
    lol!
  8. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,792
    western hemisphere
    The only time I've ever called my car an "F" car was when I was trying to take the seats out!
  9. GaryReed
    GaryReed F1 Rookie
    Feb 9, 2002
    3,127
    Seattle
    Gary
    I believe that the 308 seat rails use 5mm allen head bolts, at least my '83 308QV did...
    I would recommend that you go to your local "Tool Town" and pick up a 5mm allen head "socket drive". It makes it much easier to remove the bolts.
  10. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Well, it was close to, if not my 1st, but sure wasn't the last. Wait till you try to pull the alternator or A/C compressor. That'll be good practice. Then you'll have developed enough patience so you can exhaust it when by removing the oil pickup tube so you can pull the timing drive cover... I think it's down hill from there tho...
    Altho, there's always trying to pull a head after 20 yrs of galvanic action between the studs & AL block!
  11. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    LOL - That's a new one to me.
    Most of my firends have the problem of having their balls locked in their wife's purse.
  12. Husker
    Dec 31, 2003
    11,792
    western hemisphere
    Point well taken, Slag.
  13. Foxie
    Foxie Karting
    Oct 9, 2011
    65
    Wexford, Ireland
    Sean Murray
    Taking out the driver seat to fit new carpet and a fire extinguisher, I couldn't expose the rear allen keys.
    I did a search on here, and found the answer right away !
  14. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,773
    Cerritos, CA.
    Remove the two front Allen bolt first then slide the seat forward as far as you can to expose the two rear Allen bolt.
  15. Foxie
    Foxie Karting
    Oct 9, 2011
    65
    Wexford, Ireland
    Sean Murray
    It was Delaney's tip ( 4th Feb 2004 ) to sit in the seat and use body weight to move the seat completely forward that worked !
  16. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    761
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    Lub the spring lock .It drys and won’t open enough to move the last few inches forward.
  17. ulf308qv
    ulf308qv Karting
    Nov 1, 2003
    100
    Sweden
    Ulf M
    That worked for me in the past as well.
  18. mario marrocco
    Sep 5, 2015
    2
    Columbus, Ohio
    Mario Marrocco
    I just replaced the fuse boxes on my 1978 Ferrari gts. I made certain that all circuits were functioning as designed. One of the circuits that I repaired was the reactivating of the fuel cutout switch, which had been bypassed. The pump worked fine, it did not function without a driver in the seat. The pump also worked when I bypassed the switch. I decided to go with the original Ferrari configuration. A couple of days later, the fuel pump does not appear to be getting any, with either the original configuration
    Or the switch bypass mode. I’ve remove the seat to check the wiring which seems functional. I’ve checked all functions supported. By the 8 amp fuse in position 3. Any ideas. I could use some support. Thanks.
  19. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,413
    San Carlos, CA
    Mitchell Le
    Why did you mess with something that was working?
