Help ! remove rivet, mount rivet | FerrariChat
Discussion in '360/430' started by theodor, Aug 19, 2010.
  1. theodor
    theodor Rookie
    May 21, 2010
    16
    Europe
    Hello,
    Can anyone help me with an iformation
    How can i remove a steel rivet ,and how can i mount a new steel rivet. I saw many rivet pistols (pneumatic hydraulic) i don't now what is the best for the steel rivet.
    Did anybody change a steel rivet in a 360 or a 430?
  2. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    What I do to remove rivets is using a small steel drill bit. Go to home depot and buy new pistol and this is how you use it;
    http://www.youtube.com/watch?v=xTZAucoSymk&feature=youtube_gdata_player
  3. mr_bock
    mr_bock Formula 3
    Oct 27, 2006
    1,373
    FL full time
    What style rivet are you refering to? Solid, tubular (similar to a "pop" rivet)?
    Getting the old one out is the easy part... just drill it out (drill bit is the same or ever so slightly smaller dia. than the rivet body dia). This assumes that you can get the drill and bit into position to drill straight. Some times you can grind/cut the head (if not a c'sink head) or the expanded portion off and knock the rivet out with a drift pin.
    Installation of the new rivet depends on the type of rivet... I am sure a web search can show you options.
    Good luck!!!
  4. theodor
    theodor Rookie
    May 21, 2010
    16
    Europe
