Help removing air pump in '78 308 | FerrariChat
Discussion in 'Technical Q&A' started by Chiaroman, Sep 1, 2004.
  1. Chiaroman
    Chiaroman Formula 3
    1,689
    New Jersey
    Hello,
    I have flunked inspection because I do not have my air pump connected.
    I would like to remove it and have a motor repair person get it spinning again.
    Are there any tips or tricks to its removal?
    Thanking all you guys for your knowledge in advance!
    Tom
  2. f355spider
    f355spider F1 World Champ
    18,055
    Tom,
    There are some threads on the old site archives on air pumps. I remember someone explaining that they are not terribly complicated, and that he had opened his up, cleaned and greased the (bearings?) and got his working smoothly.
    I was told by my mechanic to adjust the belt tension on the loose side, so if the thing ever did seize up, it would be less likely to take the cams out with it; which apparently can happen.
    Here are some threads that might be helpful:
    http://www.ferrarichat.com/discus/messages/256120/241921.html
    http://www.ferrarichat.com/discus/messages/256120/189745.html
    http://www.ferrarichat.com/discus/messages/256120/8163.html
  3. FourCam
    FourCam Formula Junior
    May 19, 2004
    411
    Greeley, Colorado
    Cameron MacArthur
    I just replaced mine on a 79 308GTS. Take the old one to Checker and ask for a late 70,s GM (Camaro, Buick (ugh) air pump. You may have to take your housing off and put it on the new one; cost was 46.00 plus core charge. It is less hassle than messing with the old one which I almost guarantee is shot anyway!! These pumps were universal with slight modifications to mounting on 350c.i. engines in the GM family-trucks included.
  4. redhead
    redhead F1 Rookie
    Dec 26, 2001
    4,869
    ~Red~
    A/C Delco NEW pump is 215-143.
    I would recomend that. Slight mods, but nothing to major.
  5. Chiaroman
    Chiaroman Formula 3
    1,689
    New Jersey
    What a PIA to get that thing off1
    I had to remove the oil cooler cover to get the long bolt out of the swivel mount.
    If and when I get a new pump installed...I don't know if the air relief valve or the check valves or the "three-way electrovalvolie" is functioning properly.
    Can damage anywhere be possibility?
    I have know idea what to expect.
    Tom
