Help Removing TR Console Piece Please | FerrariChat
Discussion in 'Technical Q&A' started by Jerrari, Feb 26, 2005.
  1. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,469
    Michigan
    Jerry Wiersma
    #1 Jerrari, Feb 26, 2005
    Does anyone know the method for removing the console piece in the attached photo? (with the white "O" on it). I've removed the plate that bolts to it on the left side of the passenger's feet and I stuck my head behind there and saw (2) 8 mm nuts in the lower center, which I also removed, but that didn't seem to loosen it up at all. As you can see, a prior owner had something bolted to it and I want to get it recovered. Thanks in advance!! Jerry.
  2. Rifledriver
    37,288
    It comes out with the entire center console.
  3. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,469
    Michigan
    Jerry Wiersma
    You confirmed my fears!!
  4. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,427
    Alabama (was Mich.)
    Jeff
    There is one nut at the top of the piece too, the secures it to the main dash body. It's a little tough to get at. I do believe that the entire console must come out as one unit as Rifledriver says. You will probably have to remove the seats first, but they have only 4 allen bolts each. And the seat belt clasps may need loosening or removing. I'm going from memory here so I may be wrong. And there will be some bolts places like the storage box area, under the shifter plate, etc. Just go slow and don't pry on anything. There are a lot of wires in the console so be aware of that. Removing the entire console wasn't too bad a job as I recall.
  5. Rifledriver
    37,288
    It actually is not a bad job. The seats don't have to come out but I think it is an easier job if they are out of the way. You can kneel in there and with all the tools you will be using in there you won't have to worry about damaging the leather. I have done it a hundred times if you run into anything that gives you trouble PM me.
  6. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,469
    Michigan
    Jerry Wiersma
    Thanks fellas, I'll let you know how it goes.
