Help! Replacing 458 kick plates | FerrariChat
Discussion in '458 Italia/488/F8' started by jonny finance, Jul 7, 2015.
  1. jonny finance
    jonny finance Rookie
    Mar 28, 2015
    8
    uk
    Hi all - have purchased a pair of genuine new carbon kick (cil) plates from main dealer at a good discounted price. My car has just about every carbon option and I always felt the standard metal kick plates let the interior down..
    Please can anyone advise best course of action to change. Notice the existing ones are seriously stuck down and obviously I want to remove as carefully as possible. Was thinking maybe a touch of heat may be required to loosen whatever adhesive may be lurking underneath??? Also don't fancy pulling too hard as don't want to risk damaging surrounding paintwork..
    Many thanks
  2. Randyslovis
    Randyslovis Formula Junior
    Jul 7, 2011
    897
    Atlanta, GA
    Randall J Slovis
    I believe there was a thread some time back about this. The favored way - if my memory is correct - is basically dental tape/floss. Get it under the kick plate and work it back. If you pull up you will rip the tape. So, push down and back to get under adhesive. No harm comes to the plate as material is non abrasive.
    I haven't done this myself.
    Just repeating what I was told works.
    As mine is first response, I am SURE others will give newer/better (?) ways.
    I assume residual adhesive readily removed with the many products out there that do this.
    Best
  3. rockitman
    rockitman F1 Veteran
    May 31, 2015
    5,989
    Upstate, NY
    Christian
    #3 rockitman, Jul 7, 2015
  4. arcangel
    arcangel Formula Junior
    Jan 8, 2013
    440
    I have done it myself . Dental floss is not strong enough . Use thin fishing line first , which will break at some point . Repeat the process and then move onto to thicker and thicker line , if not eventually Guitar nylon G string . Be patient and repeat the process . It takes about an hour time to move one plate . You will make it , just a matter of time .
  5. -CD-
    -CD- F1 Rookie
    3,839
    near the Nürburgring
    Christian
    Faster, but with bending the metal plates, lift a corner and remove the plate carefully.
  6. jonny finance
    Mar 28, 2015
    8
    uk
    Many thanks all - most helpful will take my time and try the methods suggested
  7. groutguy
    groutguy Formula Junior
    Mar 9, 2014
    271
    Heat from a hair dryer will also help immensely in softening the factory two sided tape.
