458 - help- squeaks coming from front | FerrariChat
458 help- squeaks coming from front
Discussion in '458 Italia/488/F8' started by Ferraripapa, Oct 28, 2023.
  1. Ferraripapa
    Ferraripapa Rookie
    Jun 6, 2023
    18
    Goth4L
    Hey guys. Whenever I pull into a driveway, I hear a knock/sound coming from the right front end. If i were turning left into the driveway, the sound would be on the right. If i turn right into driveway, it would be on the left. The car is lowered on novitec springs. Could this be because it's lowered, it's doing something thats causing this sound? Also, when i am going over small bumps, i hear squeaks from the front as well. Anyone have this experience before I take it into ferrari and have them troubleshoot?
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Jack the front up and take the wheels off, try a pinch bar in a few suspension joints to find some slack
  3. Ferraripapa
    Ferraripapa Rookie
    Jun 6, 2023
    18
    Goth4L
    is it common to have slack in the joints though?
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    I have a 430 and it is normal but i understand the 458 is less prone
  5. Kent Adams
    Kent Adams F1 Rookie
    3,285
    If I had to guess, which is all I'm doing, it's either bad ball joints or your tires rubbing up against the fenders due to your lowering below factory height.
  6. Kent Adams
    3,285
    I never experienced that in my 430. Check your ball joints.
  7. SVCalifornia
    SVCalifornia F1 Rookie
    2,571
    Silicon Valley
    Keith
    Check bolts on the tire rims.
    SV
  8. todd cloud
    todd cloud Formula 3
    Jun 21, 2019
    1,087
    Todd
    Bearings. Ask me how I know.
    Boiler Inspector likes this.
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    I have had the lot out over the years to replace a lot will hills parts
  10. Ferraripapa
    Ferraripapa Rookie
    Jun 6, 2023
    18
    Goth4L
    How do you know
  11. todd cloud
    Jun 21, 2019
    1,087
    Todd
    my knocking noise was a failing wheel bearing
  12. Ferraripapa
    Ferraripapa Rookie
    Jun 6, 2023
    18
    Goth4L
    how much was it to fix?
  13. Boiler Inspector
    Boiler Inspector Formula Junior
    Oct 14, 2017
    353
    Texas
    Brian
    The hub assembly itself is about $2200, plus a shop is probably going to charge 3-4 hours labor.
  14. todd cloud
    Jun 21, 2019
    1,087
    Todd
    $8,967.53
  15. todd cloud
    Jun 21, 2019
    1,087
    Todd
    not covered by the Power15 warranty either
  16. Ferraripapa
    Ferraripapa Rookie
    Jun 6, 2023
    18
    Goth4L
    What kind of knocking sound? Did your springs or front end squeak at all?
  17. Sargepug
    Sargepug Formula Junior
    Mar 23, 2020
    888
    NYC
    I have a Novitec setup as well, but no issues you are stating. Post a pic of your ride height and are you running the stock rims / tires like I am?
    Here's my ride height...
  18. Ferraripapa
    Ferraripapa Rookie
    Jun 6, 2023
    18
    Goth4L
    yup. Same setup and look of it.
  19. Sargepug
    Mar 23, 2020
    888
    NYC
    Tough call then, have to defer to the installer...
