Help! Stripped drain plug! | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by UroTrash, Dec 26, 2016.
  1. UroTrash
    Jan 20, 2004
    40,682
    Purgatory
    Clifford Gunboat
    Well, I went ahead and bought this kit and it comes with a tap guide. Thanks.
    https://www.amazon.com/dp/B003SESW78/ref=aag_m_pw_dp?ie=UTF8&m=A2J41G0RQ2IUXB&tag=viglink22303-20
  2. afwrench
    afwrench Formula Junior
    Nov 24, 2004
    593
    NY
    It has been many years since I have had to do a repair like this but self tapping drain plugs were quite common at the time.Just run it in straight and you are good to go.Good luck ,Mike
  3. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    Try re-tapping to 1/2-20 .
  4. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    #29 finnerty, Dec 28, 2016
    Not all threaded inserts are created equal. There are many styles / variants and manufacturers --- and some of them are crappy.
    Whether you go with a "wound coil" type (e.g., Helicoil) or a "solid bushing" type (e.g., Time-sert), just make sure the one you pick meets either the NAS1394 or NAS1395 spec.
    These are the ones we fly on aircraft and spacecraft, and they have no design flaws and will perform perfectly --- so long as they are installed correctly in a proper application.
    Also, neither type (coil or bushing) is uniformly better than the other. It depends upon the application to dictate which is the type to use --- they each have their unique advantages.
