Help: Testarossa dumped oil! | FerrariChat
Discussion in 'Technical Q&A' started by jungathart, Mar 5, 2006.
  1. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    During a spirited drive yesterday I reached my turn around point and slowed down enough to notice a haze on the rear window. I first thought it was water from melting snow from an overpass but then recognized that it was oil. At that moment I also noticed white smoke billowing out from the engine compartment and immediately pulled over and noticed my oil pressure gauge was all the way left. Importantly, I did not hear any catastrophic noise from the engine prior to, or right after, any of this. Also, I routinely monitor the gauges and did not see any red flags raised until the incident.
    I opened the engine deck and saw that the engine wasn't on fire. The white smoke dissipated after only a couple of minutes, and there was alot of motor oil under the car.
    While waiting for the tow truck I did my best to inspect the engine bay and didn't see anything obvious.
    I called my long-distance Ferrari mechanic [Bryan Vignale @ Independent Motorworks in Short Hills, NJ :)] and after a brief discription told me it could be something with the oil filter gasket, or something non engine- related. He explained that a weak point with the TR engine is at the oil filter attachment, and that it is not unusual for the filter to blow.
    Would you please share your input as to what else this could be so I can share the info with my local mechanic: who is, btw excellent but just not Ferrari savy.
    Thanks a bunch in advance!
  2. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    White smoke? That sounds more like a coolant issue. Ok, the gauge is telling you different. This maybe a broken or loose oil line. The oil lines run from the oil tank to the front of the engine pretty well under the rear window. I would jack up the car and look up between the engine and the fuel tanks. ( the belts area ) Look from underneath as that's where the oil lines run.
    Hope this helps. :)
    Shamile
    Freeze....Miami Vice!
  3. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    Thanks Shamile.
    btw, how do you like your TR? :)
  4. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    PM Brian Crall ("Rifledriver" on FChat) - he's our resident Bay Area TR guru...
    Aaron
  5. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    If you dumped all the oil out due to a oil sealing failure its important the motor didn't get hot as well, was the water temp normal?
    White smoke can be oil burning on hot engine parts, it also has a stench too, hopefully nothing major is damaged such as a head gasket or oil starvation issue causing bearing failures. I'd drain the oil if any is left from the sump on the motor and examine the sump plug for any metal bits.
  6. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    Will do.
  7. ^@#&
    ^@#& F1 World Champ
    12,091
    dump some vineager in there and make yourself a salad :D. In all seriousness, I really hope that you get it fix. That car is soo pretty.
  8. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    Water temp was normal. I do recall the stench of burning oil.
  9. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    I think she'll be OK.
  10. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    It will probably be okay boxer motors are tough, close call though.
  11. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    I'll let you know. I see that you have a 512BB: I am so jealous!! I think it is one of Ferrari's most sensual shapes.:)
  12. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    How cold was it outside? Revving a motor with cold thick engine oil can cause the oil pressure to be so high that it will blow the seal out on the oil filter.
    You could switch to synthetic oil if you aren't already using it, or wait until the engine oil temperature comes up before revving the engine hard.
    Did you notice how high the oil pressure gauge was reading before the white smoke started?
    Brian
  13. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    Outside temp was in the high 20s, and I let the engine warm up before starting the sustained high revs. I also use synthetic oil.
    As stated before, the gauges read normal before the incident.
  14. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Hopefully you've mearly been UFI'd.
    Check the filter seal.
    Quick reactions likely saved your bacon.
    Watch the oil vicosity/ temp & pressure.
    Make sure to torque your filter.
    I use 17ftlbs (if my memory is correct).
    Good Luck,
    Vince
  15. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    Yes, good news I have [in Yoda voice]
    The gasket on the oil filter failed. I take it that this is being UFI-ed.
    I should be getting a new filter from T-Rutlands tomorrow.
    Even with proper torqueing, can this likely occur again??
  16. Steve Magnusson
    26,764
    One thing that I've taking to doing (based on advice given here) is to reverse the D-ring gasket on the TR UFI oil filter so that the flat side is towards the flat engine flange and the curved side is towards the oil filter groove -- haven't had a problem (but then I don't have any long-term experence with the "normal" way to compare it to either).
    I thought there was also an audio "buzzer" to warn of no oil pressure -- but let me check that (I may be confusing it with some of the other myriad buzzers ;)).
  17. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    Huh ??? The last 2 UFI's I put on the gaskets were flat facing the engine. These were UFI # 23.192.02 perhaps the D-ring gaskets were on the older 23.192.00 models ?
  18. Steve Magnusson
    26,764
    I'm not sure what the UFI part number is that I've used lately (and I tend to buy a couple~few at a time so my "last" one may not have been that fresh). It wouldn't surprise me at all if they've changed over to a more rectangular-shaped gasket (as they have on the UFI V8 oil filter) -- I'd almost prefer that since that's one less decision to make ;)
  19. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    Steve,
    Thanks for the tip.
  20. FarmerDave
    FarmerDave F1 World Champ
    Jul 26, 2004
    15,780
    IgnoranteWest
    Anybody ever seen Escanaba in da Moonlight?
    This thread reminds me of that line,
    "My Chevy Chook a Chit"
  21. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    Easy on the Cuervo there, cowboy! ;)
  22. Steve Magnusson
    26,764
    #22 Steve Magnusson, Mar 7, 2006
    I checked my records, and I've only ever used the 23 192 00 UFI oil filter so haven't seen the ...02 type yet -- I hope they have improved the seal design ;)
    Item 14 in this TR SPC illustration is described as:
    "Buzzer for lower oil pressure and exhaust high pressure"
    for the US and CH version TR. I'd bet most so-equipped TR have have had theirs disconnected due to flaky overtemp warning light ECU operation (mine was unplugged when I got it). Anyway, just an option to investigate if you'd like an additional, more-obvious, and quicker warning when/if an oil pressure problem occurs.
  23. Steve Magnusson
    26,764
    Poor proofreading -- should be:
    "Buzzer for lower oil pressure and exhaust high temperature"
  24. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Glad to see it was just a filter seal !
    ...I really like the TR. I don't like anything beyond the TR series (TR, 512,M) of Ferrari. I really like the extravagant styling and wide back.
    I do hate that "engine out" servicing and stupid switches. My old 308 had such great solid toggle switches for everything.
    With this board's help, owning a TR is more of a pleasure than a headache. ( I know, which Ferrari isn't a headache :) )
    Shamile
    Freeze....Miami Vice !
