HELP!!! THAT DAMN CLOCK | FerrariChat
Discussion in '348/355' started by tr0768, Jul 9, 2018.
  1. tr0768
    tr0768 Formula Junior
    Oct 28, 2008
    736
    Lake Stevens Washington
    Howard Musolf
    So I have a 94 348 spyder, with a digital clock that just flashes 12:00 continuously. So I have tried to set the time and then it reverts to the 12:00 flashing. How do you correct this or get to the correct time setting?
    thnx
    tr0768
  2. m.stojanovic
    m.stojanovic F1 Rookie
    3,294
    Serbia - Niš
    Miroljub Stojanovic
    It is possible that your AC ECU has lost its permanent 12V supply which, amongst other things, maintains the clock time (also when the ignition, and the clock display, are off). This supply comes, via a thin brown wire, from the connection of the "hidden fuse" to the AC relay and goes to Pin 1 of the AC ECU connector (see the pinout below). Inspecting and cleaning the connector may solve the problem. If you find that you have permanent 12V on Pin 1, then perhaps cleaning of the AC ECU's internal connector pins (between the two "sandwich" pc boards) may be required. If this still does not solve the problem, then the clock circuitry has probably failed.
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    The reset procedure is on page H7 in the 348 workshop manual. It should reset easily if you follow the correct steps in the correct order.
  4. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    792
    Treasure Coast Florida
    MATT
    You're probably not setting it correctly it is a bit confusing cuz when you set it you can actually set the seconds and then it gets very confusing. Just set the hour and the minute and try that.
