348 - Help! This gear oil doesn't look right | Page 2 | FerrariChat
348 Help! This gear oil doesn't look right
Discussion in '348/355' started by Huskymaniac, May 23, 2021.
  1. Qavion
    Qavion F1 World Champ
    14,601
    Ian Riddell
    #26 Qavion, May 26, 2021
    All I could find in the books was "ZF lamellar self-locking differential" with 40% lock.
    FChat tells me there are no hypoid gears of any kind in the transaxle, which may help with oil selection.
    308 GTB and Bertil like this.
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I read the same thing about no hypoid gears, however the type or material of synchro rings may be an issue with certain oils. I forget what exactly but it s out here somewhere.
  3. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #28 Ferrarium, May 27, 2021
    Nope I am using " SHELL SPIRAX S5 ATE 75W90 " Spirax S5 is the only Ferrari approved gearbox oil for many Ferrari's. Works very well. Many people don't use it because its expensive and or hard to find, which its not actually, or assume there is some other secret oil out there. Its sort of fun to search for it. :)
    What's tricky with our cars is the GB is hand made so tolerances are different and some oils work well in one GB but not in other GB's.
  4. heinz_r
    heinz_r Rookie
    Mar 11, 2019
    25
    Henry Miller
    GTO Joe likes this.
  5. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Fantastic, would be good to hear others if they use it!
  6. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    And it's a GL4 which the 348 calls for in the specs. Keep us posted. :)
  7. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Lol
  8. Huskymaniac
    Huskymaniac Formula Junior
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    Well, I already bought the Redline 75W90NS. For what it is worth, Redline specifically says this oil cross references with the Spirax S5 ATE 75W90. And the Shell comments on their oil hint at it being heavily based on esters which the Redline is also. I will see how it goes. If I get any binding I will add some Lubegard friction modifier. I already have that on hand and Lubegard is also a great product. Next time I may try the Spirax and directly compare.
    And I agree on the tolerances. It is similar to what I said about mileage and wear being a factor. As these age, more bite will be needed.
  9. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I guess you will find out. Best bet is what your doing, try what you have, you can always change it, maybe its amazing for you. :)
    I am in Central NJ, come down and try mine.
  10. Rifledriver
    37,299
    Every Ferrari trans since the 308QV and BB have oil pumps. The pump is not there for the purpose of pushing oil through the cooler.
    Even Daytonas and 330 GTCs had oil pumps in the gear boxes.
