360 - Help! Turn Signals/Hazards Not Working! | FerrariChat
360 Help! Turn Signals/Hazards Not Working!
Discussion in '360/430' started by the industries, Aug 9, 2022.
  1. the industries
    Dec 18, 2021
    27
    Ontario, Canada
    Ian
    Hello everyone, looking for some help on my 360. I was having some issues with my turn signals and after troubleshooting the obvious items, I decided to change the flasher relay located underneath the glove box.
    Unfortunately in my haste, I did not disconnect the battery and when trying to pry out the old flasher relay I shorted something (there was a small spark), and now with the new flasher relay installed all of my turn signals/hazards are not working - worse off than before lol! I do not hear the relay click, and I do not even get any lights on my dash indicating that I am turning left or right.
    I have located the fuse 23/24 for the dipped lights in the trunk fuse box - they are ok, and relay 36 in the trunk for the dipped lights - also ok. Is there a different master fuse for the main power on that flasher relay? Any other fuses you can suggest?
    Thanks in advance!!
  2. Qavion
    Qavion F1 World Champ
    14,646
    Ian Riddell
    Hi, Ian, welcome to the forum. There are a few fuses associated with the Hazard/Turn system. Is your clock also not working? If not, try fuse 43 behind the right hand seat. Fuse numbers vary, so make sure that the fuse is for the "clock, radio, wing mirrors, light switches". It's a blue, 15amp fuse.
    The other fuse associated with Hazard/Turn is fuse 9 in the frunk. That fuse also powers the frunk light.
    It's labelled something strange like "Luggage Compartment Light/Emergency"
    If the ignition was off at the time, then most likely it will be this fuse. It's permanently live.
    Hope this helps. Let us know how you go.
    Cheers
    Ian.
  3. the industries
    Dec 18, 2021
    27
    Ontario, Canada
    Ian
    Thank you very much! That was exactly it - Fuse 9 in the frunk.
    The only problem I have now is I am back to my original one - the flasher relay did not solve the turn signal issue. My rear left turn signal light is not working, the flasher relay flashes quite fast when turning left. It works normally when turning right. The front left bulb flashes, just not the rear. Obviously I have changed the bulb already. Any suggestions of where I should dive deeper? I should also note that the reverse lights are not working. Brake and tail are working correctly.
    Any suggestions would be greatly appreciated! Thanks!
    Qavion likes this.
  4. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    927
    Georgia
    Mark Gronsbell
    I would check to make sure that you are getting power to the bulb socket.
    f355spider and Qavion like this.
  5. Doctor Mark
    Dec 15, 2005
    927
    Georgia
    Mark Gronsbell
    If you are getting power with the flasher activated then it is a bulb or socket issue. Sometimes even new bulbs are defective. Always start with the simple first. Usually a rapid flasher noise indicates a bulb is out.
    Qavion likes this.
  6. Qavion
    14,646
    Ian Riddell
    Here's the wiring for the LH rear tail light. The LH turn signal wires are blue/black ("LN")
    For reference, if the wire colours are not visible, Ferrari draw their plugs as viewed from the wire side (not the contact side), so you'll have to flip the plugs (mentally) to figure out which pins/sockets the wires correspond to when doing wiring checks.
    Make sure you have a good earth ("34L")
    Does the light work when you turn the immobiliser on/off?
    (EDIT: The diagram may show a Euro car. I'm not sure how different Canadian cars are)
    the industries likes this.
  7. the industries
    Dec 18, 2021
    27
    Ontario, Canada
    Ian
    Awesome thanks for the information. I’ll try and get at it again over the next few days and update with what I find.
    Thanks again, very helpful community!
  8. the industries
    Dec 18, 2021
    27
    Ontario, Canada
    Ian
    @Qavion Yes - I just tried the immobilizer and the left rear taillight flashes as it should like the right rear taillight - so it appears bulb and the connections at the back are ok. With that information, where do you think I should be focusing my attention to? Do you have an image where that rear harness goes to in the car?
    I should note while I was doing some troubleshooting in the car that for a brief moment when trying the turn signal right I did not get anything at all - no indicators on the dash and the relay wasn't clicking at all. The hazards did work (still no left rear light), and then with moving the turn signal a few times I was able to get the right turn working again. This time it almost felt 'lazy'. The relay was making contact longer than normal and making almost a fluttering noise? Hard to describe. After about 30 seconds it went back to working normally - other than the left turn still flashing quickly and the rear bulb out.
    Appreciate any insight you can share! Thank you!
  9. Qavion
    14,646
    Ian Riddell
    Ugh.... This is getting complicated. I wonder if you damaged something other than the fuse. Something to consider... I have changed a Hazard/Flasher Module with a new one and the new one was worse than the old one! If you are now getting a problem with the right hand side, I would certainly consider this. Also, make sure your car's battery still has plenty of juice left in it.
    Interesting. The wiring which comes from the Immobiliser ECU and goes to the tail light is spliced into the wire coming from the Hazard/Turn Module ("relay"). This is splice "S79D". So the problem seems to be a wiring issue between the relay to this splice. Unfortunately, Ferrari don't show the location of splices in their wiring diagrams. Anyway, I would do a continuity check of the wiring between the relay and a specific plug at the rear of the cabin (or the tail light) to confirm this. Unfortunately, the wiring is quite complex. I'll include a diagram which includes all the wiring from the flasher unit to the rear of the cabin, including the immobiliser.
    https://www.dropbox.com/t/WdDBpEHlf9T44dcx
    The "relay" is shown in green in the middle of the wiring diagram. Follow the blue/black (code "LN") wire (on pin 6 of the relay) down the diagram to splice "S71C" to plug 10D/23D. The immobiliser/turn splice ("S79D") will be between plug 10D/23D and plug 11H/23H.
    Plug 11H/23H is shown below:
    This diagram will help you identify pin 6 on the relay (if you can't see the wire colours)
    As you can see from the big wiring diagram, the LH output from the relay goes to the Hazard button on the centre console, the instrument panel and both front and rear LH indicator lights. (EDIT: When you activate your Hazard Switch on the centre console, does the switch itself flash?)
    Let me know if this is getting to complicated for you :D
  10. Qavion
    14,646
    Ian Riddell
    #10 Qavion, Aug 12, 2022
    Do you mean the left front turn bulb or the turn indicator on the dash flashing quickly? Is the dash indicator working for left turns?
  11. the industries
    Dec 18, 2021
    27
    Ontario, Canada
    Ian
    Thank you again, you are very helpful! I actually really enjoy electrical troubleshooting, just tough when you are working blind. Where are you getting all of these schematics? It is fantastic! I will be by the car to dig in further tomorrow and let you know how I make out, and for future people with the same problem.
    Yes, the LED on the switch flashes when you activate the Hazard Switch by the gear shifter on the centre console.
    The car is currently back at the original problem - when turning left, the flasher relay is flashing quite quickly - the front left turn indicator bulb is flashing quickly but nothing on the rear. The turn indicator on the dash also flashes quickly. When turning right, it works how it should. Normal speed, indicator on dash and right front and right rear bulbs are working. I attached a video file showing the dash earlier.
    Again, thank you very much for your help!
    Qavion likes this.
  12. Qavion
    14,646
    Ian Riddell
    #12 Qavion, Aug 12, 2022
    I made them myself. I just put the jigsaw puzzle in the WSM together.
    Working with what you've told me, I see a problem between splice S71C and splice S79D. Unfortunately, the splices shown in the WSM may be one splice with lots of wires coming out into/out of it, or there could be multiple splices represented diagrammatically by a single splice.
    All you can really do is find connector 10D/23D and carry out wiring checks between the relay and the corresponding side of the connector. If that checks out ok, then there is a problem somewhere in the console tunnel or behind the driver's seat. This is where it gets more complicated. You'll have to find connector 10D/23D. It looks like it's under the console forward of the gear lever/selector.
    Then carry out a resistance check between the relay (pin 6) and plug 10D (pin 9)
    If ok, then you'll have to carry out a resistance check between plug 23D (pin 9) and plug 11H (pin 12) behind the driver's seat (see post #9). Maybe you'll get lucky and find a dirty or slightly bent pin on connector 10D/23D
    Note that the flasher unit is "hyperflashing" because it's not reading the resistance of the taillight bulb (because of an open circuit or high resistance).
    Have you had any recent work done in the console area? I can't say I've come across such a specific problem like this before.
  13. Qavion
    14,646
    Ian Riddell
    Something else to consider. Sometimes splices are not wires connected in the middle of a wiring harness, but are actually two wires going into one pin on a connector.
    Check for two wires on connector 11H pin 12.
  14. the industries
    Dec 18, 2021
    27
    Ontario, Canada
    Ian
    @Qavion - I just wanted to say thanks for all of your help. I had some other work that needed done on the car so I sent it to Daytona Autos (top notch shop for anyone in Southwestern Ontario, highly recommend them), and they found an issue on the 23D/10D connection. Thanks again!
    Just for future reference, at least on my car it is just a single wire going into 11H pin 12
    Qavion likes this.
  15. Qavion
    14,646
    Ian Riddell
    Excellent. As I said earlier, the symptoms were very specific, so I was almost sure that the problem was in that area. I wonder what caused the problem.
    By the way, did you point them in right direction or did they work it out themselves? It would have been difficult to diagnose the problem with only the standard WSM wiring diagrams.
    Thanks for the photos and feedback on 11H pin 12. I guess the splice is hidden in the harness somewhere.
    Cheers.
  16. Qavion
    14,646
    Ian Riddell
    Never having worked on the 360, I find these type of photos very helpful, if not fascinating.
    I didn't realise that plug 10H/22H (above 11H/23H) was blue and that the plugs were neatly mounted to the bulkhead. I'll add this detail to my wiring diagrams.
    I see you have a gated car as there is a jumper wire between the immobiliser and the starter relay on gated cars. On F1 cars, this plug goes to the F1 ECU. I also see you have a battery charger pigtail behind the driver's seat.
