HELP! Valve Shim Removal Tool Needed. | FerrariChat
Discussion in '308/328' started by mwr4440, Oct 26, 2014.
  1. mwr4440
    57,885
    Bavaria, The 'Other' Germany
    Mark W.R.
    #1 mwr4440, Oct 26, 2014
    I am replacing valve shims to correct the gaps to within factory specs. Engine is in the car. The wedge and half-moon tools are seemingly impossible for me to use on cylinder #6 for example.
    Can any one tell me about a tool like this?
    Will it work?
  2. Jet Lag
    Jet Lag Karting
    Dec 6, 2003
    173
    Seattle
    Robert Bangs
    Getting the bucket and shim depressed can done with a screw driver; it doesn't have to have that claw shape. Keeping the bucket depressed while you remove the shim only requires a piece of steel or whatever that is a little thicker than the shim and has a sharp edge (if it's rounded at all the pressure of the tension on the bucket will kick it away). The specialty tools look cool, but it's really a pretty simple process: depress the shim (with either a screw driver or some expensive tool)*, wedge a piece of steel/ ?? to hold the bucket down while you remove the shim.
    * I actually use 2 screw drivers, one from each side, to depress the shim/ bucket, then hold them down with one screw driver while I slip a small piece of steel in to hold the edge of the bucket freeing up the shim.
    Good Luck!
