HELP! window regulator for the 360 Modena | FerrariChat
Discussion in 'Technical Q&A' started by axis007, Apr 8, 2004.
  1. axis007
    axis007 Karting
    Jan 6, 2004
    83
    Does anyone out there have any experince on replacing or repairing the window regulator onthe 360 Modena, my car is out or warranty and the window does not seal tight after the door is closed. Hence I have some wind noise at high speed. as you know the window drops about an inch when the door is open and close it to a tight seal as the door is closed. Does any one have any experince in installing a replacement unit or the cost associate to it. I heard the window regulator is well over $1,000.00 (ouch) please help!
    or I can drive with the window roll down all the time!
  2. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,473
    Canada
    Newman
    If I had the coin for a 360, I wouldnt complain about a G note for a window repair. You know what they say, if you can afford the car, you can afford to fix it.
  3. F-passione
    F-passione Karting
    Mar 31, 2004
    173
    Orange County, CA
    I don't blame you for not wanting to drop a grand on a fix for that. I'd call around to an independant and see what they can do. There are shops around with wrecks that I'm sure would replace it with one for at least half. Finding a shop like that is in your best interest as your car is out of warranty.
  4. roccapalumbo
    roccapalumbo Karting
    Mar 16, 2004
    135
    ohio
    robert
    Axis007, I had the same problem on my 99 360 and had it fixed at an independent ferrari only shop(NJB in westerville, ohio 614-891-5678 they advertise in the FCA news bulletin )for minimal expense. Not $1000, typical dealership pricing.LOL
  5. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,963
    The Cold North
    Tom
    Time to anti-up bro. You bought an expensive car. Now it's time to pay the expensive prices. But you maybe surprized. It could be just a minor adjustment required that will only cost a couple of hundred bucks. But you'll never know unless to take it in to have it looked at.
  6. henryk
    henryk Formula Junior
    Dec 9, 2003
    479
    Door County, WI
    While I am not familiar with the 360, my MB 320 SL does the same thing.........window opens about 1/2 inch, as the door is opened.........then closes as the door is shut. I may be wrong, but my assumption would be some timing relay that is defective, thus not signaling to the window motor to open/close, rather than the window motor. This should be cheaper than replacing the window motor.
    This is just a logical guess.
  7. thomas_b
    thomas_b Formula Junior
    Sep 15, 2003
    765
    the windows are actually controlled by an ECU and you need to have an SD2 shop computer to actually do any sensible diagnostic/repair work
    not sure what exact problem you have – does the window not close all the way up or do you have only noise problems at high speed – at speed over 130km/h with windows closed the ECU will trigger small movements of the window to keep them closed
    the difference between upper limit & pre-set lower limit (if door is opened) = 22mm - if the pre-set limit is not reached the window will not close (reach upper limit), i.e. the automatic will not be activated if the window is positioned below the pre-set position - you might want to check/play with this
    window position is controlled by a micro switch – the switch might be out of alignment – I would let the F dealer diagnose it and work from there
  8. Diablo
    Diablo Formula Junior
    I would try this first
