Help with 1975 308GT4 brakes | FerrariChat
Discussion in '308/328' started by SLS4SPL, Jan 6, 2016.
  1. SLS4SPL
    SLS4SPL Rookie
    Jun 27, 2013
    9
    Downey, California
    I am having trouble sorting out my brake system. I have rebuilt all four calipers new rotors and pads. Also had booster rebuilt and replaced check valve. Pedal is very stiff and hard to stop. Any help or suggestions would be appreciated.
  2. bjmurph
    bjmurph Rookie
    Feb 1, 2011
    11
    Hi, are you getting vacuum at the brake booster? Easy way to check; with the engine off pump the brake pedal a few times, then while holding down the brake pedal, start the engine. If the pedal sinks on startup then you have vacuum at the booster. If not suggest you check the hose from the engine to the brake booster. Good luck.
  3. SLS4SPL
    SLS4SPL Rookie
    Jun 27, 2013
    9
    Downey, California
    Plenty of vacuum. No leaks from hose.
  4. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,812
    Cerritos, CA.
    There should be a one way check valve for the vacuum, if that's installed backwards, you'll not get power brake. Check the valve if not, check for kink or pinch vacuum hose. Not sure where on the GT4 but, here's a pic from "ramosels" 308.
