help with 308 jack | FerrariChat
help with 308 jack
Discussion in 'Ad Archives' started by RED GTS, Nov 14, 2015.
  1. RED GTS
    RED GTS Formula Junior
    Jun 14, 2004
    578
    Gungnir
    #1 RED GTS, Nov 14, 2015
  2. DenisC
    DenisC Formula 3
    Oct 11, 2009
    1,132
    #2 DenisC, Nov 14, 2015
    Jack is a Battaini, they were supplied to various manufacturers and all have slight design and size variations: Long jack/short jack, small base/large base, low ride/ high rise top mount, with or without a locator snub on top, with or without a thumbwheel on shaft. I am not an expert, but it seems to me the Ferrari jacks are yellow, the Lancia are blue and the Lambo/Maserati / DeTomaso are black.
    I went thru this looking for the correct jack for my car. Has to buy 3 different jack to finally get the correct one
    Here is a diagram to help measure and properly identify.
    If yours is the larger model with the larger base I would buy it from you at the right price
    Denis
  3. BigTex
    79,386
    Houston, Texas
    Bubba
    Early 308 jacks are yellow, later QV and 328 jacks are black, as yours..
    Post the dimensions and I can compare as I have both.
  4. BigTex
    79,386
    Houston, Texas
    Bubba
    it actually DOES look more robust than the 308 jack, but not sure.....
  5. RED GTS
    Jun 14, 2004
    578
    Gungnir
    Thanks, Here are the dimensions
    A. 5 1/4
    B. 2 1/4
    C. 1 3/4 OUTSIDE OF RIVET
    D. 6 1/2 OUTSIDE
    E. 1 3/4
    F. 3 3/4
    G. 6 sided 19mm
