HELP WITH 348 SIDE MIRRORS FUZE | FerrariChat
Discussion in '348/355' started by tommygunct, Mar 20, 2014.
  1. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    OTH MY SDE MRRORS JST STOPPED WORKNG CAN SOMEONE HELP ME WTH WHERE THE FZE S FOR THE MRROR MOTORS OR ANY THOGHTS ON WHY F NOT THE FZE WHAT T MAY E MAYE THE CONTROL OR i dont have a clue they never broke my stones before thanks tommy gun
  2. f3forty8
    f3forty8 Rookie
    Nov 19, 2013
    11
    Alberta, Canada
    Lorne
    I just went through this last week. Here is a link that helped me out from an earlier post.
    My problem was in the mirror switch itself. You can easily pull the switch out and check the connections. By playing with the switch connection you may get one or the other to work. I took the switch apart for a good clean, be careful to pull it apart slowly as there are several small parts and springs that you will need to put back together.
    A quick check to tell if it is the fuse would be if your wipers and stop lights have quit working. I'd check that first and then the switch.
    http://www.ferrarichat.com/forum/technical-q/94847-348-side-mirrors.html
