help with a flooding carburetor | FerrariChat
Discussion in '206/246' started by jnk, Apr 30, 2017.
  1. jnk
    jnk Formula Junior
    Nov 12, 2010
    343
    I went to start my Dino today and noticed gas leaking on the floor. I opened the carburetor box and noticed that the passenger side carburetor was full of gas and the other 2 were not.
    Any ideas what is going on and how to solve?
    thank you
  2. dm_n_stuff
    Dec 10, 2003
    43,661
    26.806311,-81.755805
    Dave M.
    Sounds like a stuck float.
    I watched a Ferrari sales manager tap the carbs on a 275GTS that was doing the same thing a number of years ago at a car show. It did free up the float, but wisely I think, the owner opted to put the car on a flatbed and return it to the dealer for service anyway.
    Engine fires are no fun.
    However, my best guess is still stuck float, overfilling the carb.
    D
  3. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    627
    Massachusetts
    Joe
    #3 jmaienza, Apr 30, 2017
    1. As noted above, could be a stuck float. Also check to see if the float is still airtight (pinhole or broken solder connection)
    Opening up the top of the carb will allow you to determine if the float moves easily. Taking the float off the hinge pin is not too bad a job, however the hinge pin should only come out in one direction. Plenty of instructions online or in Weber manuals
    2. Could also be a worn flat valve that is not fully sealing. Float valve is easy to replace.
    Diagnosis should be relatively easy because it is limited to only one carb.
  4. swift53
    swift53 F1 Veteran
    8,147
    E.S.
    Alberto
    Can also be a sunken float if it is an OEM brass type.
    Take it out and shake it, if it has fuel in it, toss it.
    While you are at it, 3 new floats + 3 new needle valves.
    Best line of action would be a full rebuild of the carburation system.
    Regards, Alberto
  5. daviekj
    daviekj Formula Junior
    484
  6. jnk
    jnk Formula Junior
    Nov 12, 2010
    343
    Thank you for all of your suggestions. I tried tapping the carburetor to unstick the float, but was unsuccessful. The car only has about 200 miles on it since a full engine rebuild.
    I will keep working on this problem
  7. Jumprun
    Jumprun Karting
    Feb 7, 2012
    227
    Southern California
    T. Martinez
    Even if you identify the problem and fix the leak, be very careful before you attempt to crank the engine over with the starter motor. Are you familiar with the term hydro lock? It can occur when a cylinder gets filled with a liquid such as gasoline, and if it happens right before the compression stroke, you may bend a rod. To be safe, before using the starter, turn the engine over by hand through several revolution to make sure no hydro lock.
    And just to be paranoid, also consider squirting some light oil into the cylinder that is being served by the leaking carb because all that gas has washed the oil off the cylinder wall of those fresh bores.
    One more thing, your oil may need a change too because of the gasoline leaking in, pull the dip stick and take a sniff, you may get a surprise.
    Tom in SoCal
  8. Jumprun
    Jumprun Karting
    Feb 7, 2012
    227
    Southern California
    T. Martinez
    More comments regarding the problem and my probability ranking
    1. Stuck or sunken float, remove carb top to fix.
    2. Bad needle and seat, remove carb top to fix.
    3. A leak at a fuel fitting, check
    4. Too much fuel pressure, check electric fuel pump rating, does the Dino have a regulator?
  9. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    With fuel leaking onto the floor it sounds like an external fault rather than anything internal, is the engine running or just the electric pump?
    Apart from a gasket leakage try the accelerator pump diaphragm, it has tendency to get brittle and leak.
    To diagnose properly we really need more info.
  10. jnk
    jnk Formula Junior
    Nov 12, 2010
    343
    Thank you. I will take a video this weekend of what is going on and post. That may give everyone a better idea on what is going on, and hopefully allow a diagnoses.
  11. frankwissman
    frankwissman Karting
    May 6, 2006
    63
    Charleston, SC
    Frank Wissman
    I would remove the spark plugs before I turned the engine over if there is the threat of hydro-lock.
