help with Certificate Trust error? | FerrariChat
Discussion in 'Technology' started by JeremyJon, May 13, 2013.
  1. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
    #1 JeremyJon, May 13, 2013
    I've some STL files emailed to me, which I need to both open and save (in the STL format) so I can in turn resend to the 3D printers
    Problem I encounter when I try to save is "Certificate Trust List" CTL error
    It's on Gmail if that matters at all, but there is no problem with my email as received
    How do I fix this??
    I've googled it, but the few pages that come up don't speak clearly about how to fix this?
    frick'n MS strikes again, errr, grrr :angry:
  2. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    oh ya, and "HELP!" :D
  3. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    best explanation I have found so far
    http://www.pistonheads.com/gassing/topic.asp?t=904841
    ...so maybe because I don't have compatible program on my computer for opening a STL file??
    still, I should be able to save a file from email to a file folder on my computer, surely??
  4. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    Well, if anyone runs into this same issue, here is the bandaid fix I was able to use
    I got the STL files emailed to me in 'zipped' format, and instead of opening or importing the STL file, the zip file will save as normal to a folder
    For alternate emailing out, the zip file can then be attached and sent ...not the ideal, but it worked!
