Help with Connectos | FerrariChat
Help with Connectos
Discussion in '456/550/575' started by My456, Mar 10, 2018.
  1. My456
    My456 Rookie
    Mar 10, 2018
    3
    Aberdeen
    Angus McDonald
    #1 My456, Mar 10, 2018
    re. 98 spec GTA (euro) (no OBD port)
    I've been asked by a 456 owner to help identify and locate some connectors.
    1. Connectors
    They are all in the fuse box area, connectors 1 thru 6 as in the picture.
    2. Where are the Engine ECU diagnostic cables ?
    thks.
  2. stevepaa
    stevepaa Formula Junior
    Apr 5, 2006
    771
    san jose, ca
    steve
    TE connectivity is the place to look
  3. Fennicus
    Fennicus Formula Junior
    Apr 10, 2015
    593
    Helsinki, Finland
    Pekka T.
    Hi Angus,
    An old thread, no solutions except the factory SD-1.
    https://www.ferrarichat.com/forum/threads/obd-for-456.307382/
    Although I have a FIAT lead for some of the ECU's. I find it hard to believe no-one has made a modern solution for the diagnostics on these cars, I guess there are too few of them.
    The engine ECU's have their independent connectors right next to the boxes, like shown in the photos in that thread. The black connectors with the blue finishers. How to read them is another info. The factory WSM has a lot of info if you can figure out how to hook up the wires/connectors.
    Cheers!
  4. My456
    My456 Rookie
    Mar 10, 2018
    3
    Aberdeen
    Angus McDonald
    He has access to a Leonardo, with 456 model support
    And there is a cable that has 2 x 3pin connectors (they are slightly different to each other).
    Plus the two cables are label 1 & 2 - no other info came from Accinni apparently.
    Item 6 = Is this the test lead to make the rear floor spoiler move ?
