Help with CT emissions | FerrariChat
Discussion in '348/355' started by johnk..., Jun 6, 2013.
  1. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    Hi guys,
    After 3 years looking I finally found a 355 I was happy with and pulled the trigger. It's a beautiful 95 Blu Swaters/Tan with 19k miles. The car arrived from San Diego to my home in CT Memorial day. The car is everything it was supposed to be. Look almost new. Was well maintained over the years. One problem though. In CT when registering the car you need to go through emissions. It doesn't matter if it passes of fails (weird), but you have to go through the test before they will issue plates, and being a 95 it requires a sniff test.
    So, the car came with a CA emission report from February 2013 which showed it passed, no problem. As part of the sale the car had a full major. Long story short, a couple of months, a major, and 400 miles later and the car fails CT emissions with HC over the limit and CO just missing. Other than that it seems to run flawlessly. No codes in the ECU, no slow down lights. I plan to have someone analyze the exhaust gas at the header ports, before the cats, but honestly, I don't know where to start. The workshop manual say something that leads me to believe that if the left and right bank injectors aren't correctly balance at idle it could result in excessive CO and HC.
    Any idea or assistance on what to look for would be appreciated.
  2. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    Nothing? No one has had any emissions problems with a 95 355 (OBD I)? Guess I'll have to have a SD 1 scan done.
  3. plugzit
    plugzit F1 Veteran
    7,789
    Redondo Beach, CA
    Bruce Bogart
    Does it reach 190 deg running temp?
  4. fatbillybob
    Aug 10, 2002
    29,244
    socal
    A long 3000k tow lots of vibration. I would try disconnecting and reconnecting all sensors and connectors. Then a nice long drive to get it good and hot. Then do a smog pretest. Sometimes it is just connections. Sometimes you got a real problem and it is not a ghost. If it is a ghost consider the SRI gold kit. Works like magic. Also check the major work order. Almost never is there an in out injector service but the car has few miles but is very old. Junk builds even if sitting and poor injector patterns don't help. Also, doing a ECU relearn can make a difference because some smog tests are done at idle. If the battery was off during the long tow and then reconnected without proper relearn the system will not be running at peak efficiency. Stone cold motor, everything off, let it idle 15mins
  5. plugzit
    plugzit F1 Veteran
    7,789
    Redondo Beach, CA
    Bruce Bogart
    Good call.
  6. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    Pretty much the usual suspects. Both the tech and the selling dealer suggested to drive it and get it hot before testing. I did that, but the car sat for over an hour before the tech could get the testing equipment up. I guess I run through the short list and try a retest. Thanks for the suggestions.
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    "fails CT emissions with HC over the limit and CO just missing"
    What comes to my mind is, are the cats OK. Secondly did they advance the exhaust a few degrees for a bit more gogo? This alone will increase HC and CO. Mines is right on the limit cant remember off the top of my head the numbers
  8. plugzit
    plugzit F1 Veteran
    7,789
    Redondo Beach, CA
    Bruce Bogart
    Cold cats may be guilty here. The hotter the better. They don't work cold.
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Yes if it was shut off the cats are cold. I read it wrong I thought you were idling an hour waiting for the test. I need new glasses
  10. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    #10 johnk..., Jun 9, 2013
    Cold cats could be the problem but let me ask this, if the left and right side throttles are not correctly balanced could that cause some cylinders to run rich resulting in high HC emissions? I ask because the heads were off for guides and when put back together the balance could be off compared to before the engine was torn down.
    The CT test was run at 2260 RPM, I think in 3rd gear (25 mph equivalent) which seems the same as the CA test.
    CA test results were: HC = 44 ppm, CO = 0.15%, NO = 58 ppm
    CT results were HC = 140 ppm, CO = 0.50%, NO = 219 ppm
    Anyway, had it out today. Still seems to run great otherwise. Oh well, in 7 years it won't need to go through emissions. :)
    I should add that the PPI was done after the major service/head work and it was reported to have checked out fine. But I wish I had asked the selling dealer to take it through a CA smog test again so I would have numbers I was sure of. The consensus seems to be to get it hot and test again.
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,655
    San Carlos, CA
    Mitchell Le
    Do you have the high flow cats? They have worse readings than the stock cats.
    Do what FBB said and unplug the battery, reconnect and let it idle for 15 minutes, observe that it does hit 190 degrees F (what Plugzit said) and observe that the secondary fan(s) come on at 190F and the coolant temp goes down after that. That will tell you that your coolant system works and the car is not running too hot or too cold (open Thermostat). All of which will have an effect on emission.
    Ernie had a problem passing smog when his thermostat failed and eventually ruined his cats.
    Then, do what you said earlier and get the car nice and really hot before the test again.
  12. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    Yep, I'll try it all. It has stock cats, but they are not the original. Cooling system works correctly. Fans come on as required at correct temp (about 190) and temp drops, fans go off and temp rises. Fans cycle.
    Fundamentally everything should be good. So I will try the ECU relearn, get it hot and have it tested again next week.
    I also wondering if disconnected the vacuum line (and plugging it) from the bypass valve so that all the exhaust passes through the main cats would help. I'm think that the main cats should be more efficient than the bypass cat.
    Thanks to all for the suggestions.
    If I can't get it passed I think I will apply for what they call a Functional Diagnostic waiver.
