My passenger side window appears not to be travelling up the rail as it should. So I remove the leather door trim. Then I start taking these bolts off, now the inner door frame is loose, but it appears the window, the rails, the whole mechanism is attached to the inner frame. Anyone had to change or fix their window before, and if so, how do you do it??? Stumped. Thanks Rorie
See, this is what I needed to know. You attack it from the outside, not the inside. http://ferrarichat.com/forum/showthread.php?t=59677&highlight=355+rattle
Just saw your post, that was the thread I was going to link you to. If you cannot fix, you may need to replace the window regulator.
Thanks. We will see. Even though I did my searches, someone else PMed me something under "door rattle" which was also helpful. Thanks.
