Help with friend's 348 project | FerrariChat
Discussion in '348/355' started by 6point3, Mar 27, 2010.
  1. 6point3
    6point3 Rookie
    Mar 1, 2006
    12
    PacNorWest
    Hello. I'm just trying to help a friend out with he's doing on his 92 348 engine. I've checked out some pics on this forum but cannot find what I believe he is looking for. He says he needs info on the routing of items under the intake manifold. "the vacuum lines, vacuum switches, and the 2 ground connectors." They are all there, just needs to know where they bolt/connect to. Like I mentioned, the pics i have found here on the forum of under the manifold are good, but don't show them connected. ANY help is appreciated. From him and myself ahead of posts, Thank you.
  2. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    If you're near to Tacoma, you can compare it with my '90 348ts, or if you can tell me specifically what info you need, I'll go out in the garage and make up a diagram for you if I can.
    There are electrical and wiring diagrams in the shop manual, parts book, and owners handbook.
