Help with GTS308 qv charging system | FerrariChat
Discussion in 'Technical Q&A' started by back seat driver, Jun 25, 2012.
  1. back seat driver
    Mar 14, 2011
    1
    Camas, Wa
    Bob Elliott
    when driving the car, would like to do more often, the car runs off the battery. are there some simple checks with this car to tell if its the alternator or what?
    thanks
  2. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Got a voltmeter? Test the battery voltage with the car off. Should be 12.something volts up to about 13.2. Start the car and rev it over 3000 for a second to get the alternator excited. Now measure the battery again. If the alternator works it should be higher, probably 13-something or maybe even very low 14-something volts.
    (In a pinch you can use the headlights instead of a voltmeter.)
    Does the red G light in the dash come on before the engine starts? Does it go off when running?
