Help with my 308 clock... | FerrariChat
Discussion in 'Technical Q&A' started by Husker, Jan 15, 2004.
  1. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,790
    western hemisphere
    I have a 1982 308GTSi. Clock works great, except it's about an hour behind. However, the knob the re-set the clock is either stripped or not engaged, as turning it does nothing. Here are my questions...
    1. Can just the clock lens be removed so I can re-set the clock? If so, how does it come off?
    2. If I want to take the entire clock out, how does it remove? There are two small black screws in the dash area surrounding the clock. Is this how it removes?
    Thanks in advance for your help.
  2. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    Sorry if this is too basic, but did you push it in & turn? Turning it does nothing, unless you push it in first. Again, sorry if you have had the car a long time & already know this.
  3. f355spider
    f355spider F1 World Champ
    17,950
    Yes, removing the two screws should drop that panel down...then there is one or two thumb screws that retain the clock to the panel. If I were you, I would remove the clock, and send it to a repair shop, get if fixed properly so you can adjust it periodically (daylight savings time?) and not have to disassemble it for adjustment :).
    Removing the lens is pretty tedious (but can be done) and you might mess up the retaining ring or the hands trying to move them.
    You can send it to any number of repair shops and for around $100 they will fix it, replace the plastic lens with a fresh new one (they always get scratched up and foggy looking) and warranty it for a year.
    I sent mine to Palo Alto Speedometer, but you could probably find someone in the yellow pages closer to you. Or ask your local dealer for suggestions.
  4. GearHead
    GearHead Karting
    Jan 3, 2004
    76
    Disconnect power to the clock.
    Then, when the time is correct, reconnect the clock!
  5. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,463
    Michigan
    Jerry Wiersma
    My clock adjustment knob does not work either. I hate to spend $100.00 on such a (in my mind) trivial repair, so if you guys find someone that can do it for less, please post their name.
  6. delaney
    delaney Formula Junior
    Nov 8, 2003
    704
    St Petersburg, FL
    PETER DELANEY
    I just fixed the exact same problem with my clock ... 83 GTsi QV. The problem is almost as stated in the 1st note .. but it's not the the little push in bit that's stripped .. it's metal .. it's the plastic gear it goes into within the clock.
    I did a real cheap fix ... I pulled the metal adjustment knob out ... squeezed the 'gear' bit that goes into the stripped plastic within the clock between some vice grips to flatten it. (CAREFUL ..looks like it could break real easy.) ... then pushed it back into the clock. Distorted bit gives just enough grip to adjust the clock. .. I know ... cheap cheap .. but have you checked the cost of a replacement!
    I'm currently looking for another standard clock ..Pepboys etc ... that I can use the internal bits from and the external OEM bits.
  7. Husker
    Dec 31, 2003
    11,790
    western hemisphere
    Delaney, how did the metal adjustment knob "pull" out? You mean if you pull on it hard enough, it just comes out of the clock (and face) without damaging the clock?
    I suspect my gears are stripped, too. It just feels that way.
  8. rudy
    rudy Formula Junior
    Jan 13, 2004
    363
    Los Angeles California
    Rudy Hassen
    That is Brilliant. Honestly.
  9. delaney
    Nov 8, 2003
    704
    St Petersburg, FL
    PETER DELANEY
    The adjustment knob just pulled out. I've had the clock apart to try and clean the plastic, and it seems there's nothing other than an interference fit holding the adjuster in.
  10. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,463
    Michigan
    Jerry Wiersma
    Here is a copy of the response I got from a place I found on line called Don's clock shop:
    To: <[email protected]>
    Sent: Monday, January 19, 2004 10:09 AM
    Subject: Veglia clock Repair
    Hello
    Yes we can repair your clock. You really should have the clock completly
    cleaned and overhauled. To overhaul it, replace the lens, and replace the
    gear the cost is $209.95 plus shipping. Of course that would have a full 1
    year guarantee. If you decide you would like us to repair your clock please
    ship to Bill's Clock Shop 2844 Col Glenn Hwy Fairborn, Ohio 45324. If you
    dhip please pack it well, double box it and add more insurance. As soon as
    we receive it I will contact you that it has arrived safely.
    Sue
    > Hello, I am looking for someone to repair my Veglia Borletti 2" diameter
    clock out of my car. The adjustment arm does not work (I think the gear
    inside is stripped) and it needs a new lens. What would the approximate
    charge be for this?
    > Thanks,
    > Jerry
  11. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,463
    Michigan
    Jerry Wiersma
    Same question posed to Palo Alto Speedometer:
    The way that we usually handle this type of a repair is that you would ship
    your clock off to us for a free estimate. Once we have received it I would
    open the clock up and call you to discuss what I have found. The average
    repair price lies somewhere around $150.00 + UPS. This price of course
    depends upon the condition of the clock, and which parts are needed to
    repair it. We have most repair parts in stock and all of our work comes with
    a 12 month warranty. The average turn around time is about 2 weeks + UPS
    time, depending upon any unforeseen problems. If you decide to send us the
    clock make sure to enclose a short cover letter with all of your
    information, along with a brief description of the problem. We usually
    arrange payment with Visa / Master Card or Discover Card over the phone.
    Our shipping address is :
    Palo Alto Speedometer, Inc.
    718 Emerson Street
    Palo Alto, CA. 94301-2410
    Please feel free to call me if you have any questions at all about this
    process or about our services.
    Thank you,
    Hartmut C. Mees
    718 Emerson Street
    Palo Alto, Ca 94301-2410
    tel : 650.323.0243
    fax : 650.323.4632
    www.paspeedo.com
  12. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,463
    Michigan
    Jerry Wiersma
    Anyone know how to take this thing apart? It looks like you peel up the back side (lip) of the chrome bezel. Can anyone confirm this?
  13. MRFOTOS
    MRFOTOS Karting
    May 26, 2003
    232
    Maui, Hi
    yes I have done that, and i replaced the very milky lens with a new cd jewel box cover, now looks like brand new !
    but Major PITA
  14. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,463
    Michigan
    Jerry Wiersma
    Does it in fact come apart by peeling up the back side of that chrome bezel?
  15. MRFOTOS
    MRFOTOS Karting
    May 26, 2003
    232
    Maui, Hi
    YES it does, i opened it up with a small flat screwdriver very carefully on the back of the bezzel, popped the foggy plastic off and used it as a template for the cd cover plastic, then use moto tool to cut and drill the hole for the stem, then replace, all the prymarks are on the bottom and hidden when installed on the console.
  16. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,463
    Michigan
    Jerry Wiersma
    Thanks for the info!!
  17. krbrealey
    krbrealey Rookie
    Nov 1, 2003
    4
    Hello,
    I had my 308 clock serviced at Bill's Clock Shop in (Fairborn) Dayton, OH. Sue was very helpful, and they did a great job. New lense, new winding stem, and gears, and good cleaning. It looks great and is keeping time perfectly. The prices look scary, but I think they do fine work.
    Good luck!
