Help with my F355 | FerrariChat
Help with my F355
Discussion in 'Technical Q&A' started by RSO1091, Jun 3, 2012.
  1. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    I originally posted this on the 348/355 site, but thought I might get some more guidance from a broader audience. Thanks, Henry
    Have you ever done something you knew would be bad, but you did it anyway and have regretted it ever since? Well, my wife and I were enjoying a beautiful drive in our F355 two nights ago, when she mentioned that she'd like to see some of the homes off the main highway. Even though those roads are paved, I had a bad feeling but proceeded nonetheless. All was well until the final detour (naturally) when I came upon a metal cattle guard in the roadway. There is apparently an optimal speed with which one should attack such an obstacle. It's either VERY slow, or VERY fast. I can tell you from experience that, "somewhere in the middle," doesn't work.
    So here is my dilemma. Upon driving over the afore mentioned grate, the car shook violently at which time every warning light that Enzo put in the dashboard came on in unison. I drove a bit farther in the hopes that things would, "reset," themselves. When that didn't happen, I pulled off the roadway and turned off the ignition. Upon trying to restart the car however, the starter dragged (as if the battery was low) and that was that. Help was summoned and while we waited, I decided to try to start the car one more time. This time we had ignition and all of the warning lights were now off. We drove approximately three miles with no issues before the two check engine lights came back on and the car began to sputter and buck. The old girl gave me just enough power to pull off safely into a parking lot where we again waited for the tow truck. I have been unable to start the car ever since as it acts like the battery is low.
    I contacted Craig from FASTCARS in Redondo Beach (Thanks again Craig) and he and his mechanics thought that the problem could be electrical and I should check all connectors which may have shaken loose, especially the multi-pin main that is located somewhere between the front and rear of the vehicle. I located the two Bosch multi-pin plugs at either side of the rear of the car, but cannot locate that main connection. I also removed the battery and had it checked (OK) and am running out of ideas before I have to bite the bullet and pay for a tow truck transport to the beach. I'm also thinking that it might be a bad ground. Can anyone tell me where to look for those? I saw one beneath the transaxle.
    Any ideas would be appreciated at this point. I don't have ready access to a code reader specific to a Ferrari.
  2. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Chapter 2. Since the starter drags when I tried to start the car, I decided to jump start it this morning and it fired right up. I let it idle for about two minutes and it was a bit rough. The lights on the dash came on once again (although faintly) and none of the gauges were operational. as I tried to feather the throttle, the car sputtered and then just died again. So I would think that this problem is electrical in nature, right?
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,673
    San Carlos, CA
    Mitchell Le
    It is electrical and difficult to find. You need to figure out which ground points have come loose.
  4. twright
    twright Karting
    May 15, 2005
    225
    Indianapolis USA
    It sounds like the connectios at the battery are loose/corroded. Have you checked them?
  5. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Yes, I've checked the battery (which tested in the good range) and cleaned/tightened the connections. Can anyone tell me how many and specifically where the ground points are located on this car? The electrical diagram in the manual is totally foreign to me (no pun intended).
  6. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    As the gauges were inoperative when I started the car this morning, I was thinking about trying to jump starting it again, but not disconnecting the cables from the donor vehicle to see if a steady supply of voltage from that car would provide any clues or make a difference. Any potential harm in doing that?
  7. cuneo
    cuneo Formula 3
    2,484
    Try checking the connections at the alternator (sorry if you've already done this).
    I went through very similar symptoms, and after my mechanic replaced the "oldish" battery it happened again. Then he pulled the alternator and it tested fine. Turned out it was the old original metal clips on the wires going to/from the alternator had fatigued over time, and when the car heated up the metal expanded and made a bad connection. Hope your issue is as simple as this. Sorry for your troubles.
  8. 575
    575 F1 Rookie
    Nov 20, 2009
    4,658
    Sounds like a loose ground. You will need a service manual to locate them . Undo the ground and clean with emery paper on both sides.
    Could also be the connections to the ecu behind the seats.
  9. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    I agree with the 'loose ground' theory. If you can, get the car up on a lift, and start checking grounding cables.
  10. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Someone else mentioned the ECU or multi-pin connector behind the seat (passenger side), but after pulling up the carpeting, all I can see is a solid metal wall. Am I not looking in the right place?
  11. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Had the old battery tested again at NAPA this morning and found it to be bad, so I replaced it with a new one. Upon initial attempt to start the car with the new battery I just got the old dragging starter routine again. I then jumped the car with another and it started right up. Disconnected the cables and the car ran fine (although my parking brake light was flickering and the open door buzzer sounded like a wounded cat) and then everything shut down again. Looks as though I'm not getting the voltage I need unless the car is assisted from an outside source. So I'll go with the majority and attempt to locate and clean all of the grounds that I can find. After that, I'll concentrate on the alternator.
    Thanks again for all of your guidance guys. I know I'll get it figured out (hopefully) sooner than later.
  12. 575
    575 F1 Rookie
    Nov 20, 2009
    4,658
    The ecus are bolted to the firewall behind the back seat. Check the connection.
  13. sevminasyan
    sevminasyan Formula 3
    Jun 24, 2008
    1,156
    Glendale, CA
    Steve
    Make sure the ground cable from the battery is connected to its proper grounding bolts on the chassie. It may be that the battery got thrown around violently and it pulled the thick black ground cable loos from the connections under the passenger side front hood area. Need to take out the carpeting on the passenger side. There is a ground connection in front of the shock tower with a 13mm bolt. Just try to twist it by hand and see if its loos. The battery may be good but the ground may be loos and is not delivering enough juice to the car.
    Let us know.
    Steve
  14. dt930
    dt930 Karting
    Dec 2, 2004
    57
    Wisconsin
    David C. Treichel
    The ECU's for a 1995 are located under the side engine compartment trim panels, check the connections there also.
  15. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    #15 jm3, Jun 4, 2012
    If the positive battery cable terminal has been replaced, triple check the connection. There must be the big fat red wire, and a little teeny red wire connected IN the terminal.
    The battery is grounded through the shutoff switch. Check all the terminals, and even run a fresh ground across the terminals with your jumper cables.
    When you connect the other car (jumping the battery) you are bypassing the shutoff switch that is under the hood. Pay close attention to that..
    The ecus don't have much to do with engine cranking, so ignore them for now.
    Just re-read the thread. Check the ground strap from the alternator, you should eventually have two anyways, just for the sake of redundancy.
  16. sclja
    sclja Formula Junior
    392
    San Diego Ca
    Scott Cairncross
    #16 sclja, Jun 4, 2012
    I would be happy to have a look at it for you if you want to bring it to La Jolla... I have seen a issue similar to this that is a loose power connection under the pass foot rest behind the fusebox as there is a power distribution block and I have found the connections loose causing all kinds of electrical malfunctions.... Let me know if I can help you!
    Scott LJA 800-467-6545
  17. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Thanks for all of the tips guys. I am setting aside a day next week to check every friggin' connection and ground that I can find on the car. I'll let you all know how I fare.
    Henry
  18. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Thanks for the offer Scott. Unfortunately as the car is currently immobile, it won't be going anywhere in the near future. I do appreciate the thought however.
    Henry
  19. sws4re
    sws4re Formula Junior
    Jan 28, 2006
    281
    Olathe Ks
    Scott Sweat
    I agree with Steve on the battery moving around and possibly shorting out. I would check your fuses also. Could explain your dash not working
