Help with old skool radio installation (77 308GTB) | FerrariChat
Discussion in 'Technical Q&A' started by decampos, Mar 10, 2007.
  1. decampos
    decampos Formula Junior
    460
    Los Angeles
    Ben
    #1 decampos, Mar 10, 2007
    Hi Everyone. The modern radio seemed to bug me so I got a hold of a period one to put in it's place. I haven't got the manual for it so I'm struggling a bit with which wire is what. Can anyone help?
    there's 6 wires:
    red
    orange
    (assume one is power constant and one is switched)
    black
    (ground I assume)
    green
    grey
    blue
    Is there one missing?
    Sorry, bit dumb. Any help/guidance very much appreciated.
  2. decampos
    460
    Los Angeles
    Ben
    #2 decampos, Mar 10, 2007
  3. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    THIS IS WHAT I WOULD TRY FIRST, IF YOU HAVE A SCREW GUN BATTERY YOU CAN QUIKLY TEST THE POSITIVES AND GROUNDS TO SEE WHAT DOES WHAT.
    RED, POWER TO BATTERY
    ORANGE, SWITCHED POWER TO KEY
    BLUE, GROUND
    GREEN, LEFT OR RIGHT SPEAKER +
    GRAY, LEFT OR RIGHT SPEAKER +
    BLACK, COMMON SPEAKER GROUND
  4. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    ON NEWER RADIOS BLUE WIRES MEAN A SENDER WIRE, TO TURN ON POWER AMPS, ON THE ONE YOU HAVE I AM THINKING IT MAY BE POWER GROUND.
  5. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    AND IF BLUE IS NOT GROUND, THEN YOU CAN RUN ANOTHER BLACK WIRE FROM RADIO CHASIS TO GROUND ON VEHICLE. AND LEAVE THE BLUE CAPPED OFF, UNLESS YOU NEED TO TURN SOMETHING ELSE ON, OR RAISE A POWER ANTENNA OR SOMETHING LIKE THAT.
  6. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    I just found this on the internet- hope it helps-
    Pioneer's non-EIA wiring colors
    Black >> Ground
    Red >> ACC
    Orange >> BAT
    Blue >> Power Antenna & Remote
    Green >> LF+
    Green/Black >> LF -
    Gray >> RF+
    Gray/Black >> RF-
    Green/Red >> LR+
    Black/Green >> LR-
    Gray/Red >> RR+
    Black/Gray >> RR-
  7. decampos
    460
    Los Angeles
    Ben
    #7 decampos, Mar 10, 2007
    Thanks Kenneth. That's a big help. Question: if the blue wire is another ground (and not for the antenna as Steve suggested it might be), does it attach to the car and the black wire attach to the speaker ground?
    Included a photograph of the connections in the car with the existing ground (connected to the car) in the background right. Is one of the wires in my hand a speaker ground?
    Many thanks.
  8. The Rig
    The Rig Karting
    Sep 5, 2006
    99
    Tucson
    Gerry Shanks
    On some older pioneers orange was the constant, not the red. Green is left positive, gray is right positive. The radio is "common ground" so all negatives get hooked to the black. If you have a multimeter you can check for continuity or resistance between the radio case and the blue wire. If not, go with the suggestion of attaching a wire to the case for ground, and cap off the blue wire.
  9. decampos
    460
    Los Angeles
    Ben
    #9 decampos, Mar 10, 2007
    Thanks for all the help guys.
    The OM shows a diagram with 4 speaker wires and only one for power and an earth. I assume then the radio is always constant.
    So, for the wires in the previously posted pic of inside the car (the one with my hand) from left to right the wire colors are:
    yellow/green - (L speaker + ?)
    yellow/black - (L speaker - ?)
    grey/red - (R speaker + ?)
    grey - (power?)
    grey/black - (R speaker - ?)
    Does that sound right?
    Gerry: are you saying the left and right negatives should attach to the ground on the radio?
    Sorry if that's a seriously dopey question.
  10. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    IF I WALKED INTO IT NOT KNOWING, I WOULD FIRST GET POWER TO THE RADIO, THEN THE OTHER WIRES WILL BE SPEAKER WIRES, IN YOUR FIRST PIC YOU HAVE A CONNECTOR WITH THREE WIRES IN IT, THE BLACK GETS CONNECTED TO BOTH RIGHT AND LEFT SPEAKER GROUND, MOST TIMES ANYTHING WITH A BLACK STRIPE ON IT IS SPEAKER GROUND, THE OTHER IS HOT. WHEN YOU GET POWER WORKING, JUST TEST DIF WIRE CONNECTIONS ON SPEAKERS...........IT WONT HURT ANYTHING, UNTIL YOU GET IT RIGHT. I WOULD NOT HOOK EVERYTHING UP TO POWER ALL THE TIME, THE IF YOU LEAVE RADIO ON IT WILL KILL YOUR BATTERY.
  11. The Rig
    The Rig Karting
    Sep 5, 2006
    99
    Tucson
    Gerry Shanks
    You are going to have to do a little detective work here. The schematic does not match up to the radio wires you are showing on the back of the radio, so its going to require a a couple steps to get this narrowed down.
    1. Does your car have a power antenna? If yes, does it go up when you turn on the key, even without the radio hooked up? According to the schematic, this should be the case.
    2. Identify the wires you have in the dash of the car. You should have one ignition(+12v when the key is on), one ground(The one you show in the back of the pic with the spade terminal on it) And two pairs of speaker wires(R+,R-,L+,L-) You could also possibly have a 12v constant(always has power for retaining presets or clock memory. Judging by your pic and the factory schematic, this would be a wire someone added after the fact, not a factory wire.) Find the power wire first, and that should leave you four wires(speakers.) Once you verify that they dont carry any current, you can use a 9v battery to pop the speakers.(If you need a detailed explanation on how to do this let me know.)
  12. decampos
    460
    Los Angeles
    Ben
    #12 decampos, Mar 11, 2007
  13. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    COOL...............
