Help with PPI results please | FerrariChat
Discussion in '348/355' started by tbsb9595, Apr 4, 2007.
  1. tbsb9595
    tbsb9595 Guest
    Sep 19, 2006
    105
    Largo, FL
    Tom Sweet
    I just had a PPI done on a 348 with 41k miles and here are the results.
    Compression = 225 +/- 5 psi
    Leak down
    10%
    5%
    5%
    17%
    5%
    6%
    6%
    8%
    Obviously the 17% is of concern, but is it really a problem? I heard a lot of different things about leak down tests and I don't know what to believe. The thing is the car runs and idles great and the compression #'s are all very close. The car hasn't been driven much in the past year and I was told from a ferrari mechanic (with a lot of experiance) that driving it may improve the 17%. He also thought that 17% was not really a problem.
    What do you think? Any experts out there? TIA
  2. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    You are looking for a narrow band of difference between cylinders and u have 1 way out and another maginal. Could be sticky rings, could be something else. I might expand on the leak down - search for rifledriver posts on leak down tests - or I'd pass. It is greater concern to me that the 2 cylinders in question are on the same bank.
  3. f_the_ASR
    f_the_ASR Karting
    Mar 10, 2006
    149
    Now Mid-West
    Joe Polinchano
  4. Rifledriver
    37,252
    I am highly skeptical of the results. A 348 does not have enough compression to generate 225 lbs in a compression test. Also no reason is given for the loss in #4. 17% leakage is not hard to trace. Determining the source is part of the job.
    This test and many like it I read about here makes me wonder what people are paying for. There is never complete information provided. Choosing a person to perform a PPI is very important and it seems it is not often done properly. Your mechanic should be able to provide the answers to your questions and evidently he has not...at least to your satisfaction.
  5. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    When I did the PPI for my car last year, it was around 180psi with <5 percent variance across all cylinders.
  6. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    Who did the PPI? My numbers were similarly strange...
  7. Rifledriver
    37,252
    Makes me wonder how many are done with a sharp pencil.
  8. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    Very very important the mechanic knows what he is doing when he performs leak down tests. Have seen MANY results that have been all over the place, because of an inexperienced mechanic performing the job. Take the car back or call him and tell him to look further into that dodgy cyl. :)
  9. UConn Husky
    Nov 11, 2006
    4,425
    CT
    Jay
    Mine was done with a crayon. As for an explanation of the results there was some difficulty as nobody else at the dealer's shop could translate from the guy who actually did the testing...but apparently he had extensive experience on diesels, oh yeah! This is why I'll only let experienced techs with recommendations work on my car...
  10. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    That's pretty funny....but also sad for the unaware owner
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    How can an engine physically have a high compression with large leaks? If a balloon has a big leak, will you be able to compress the air inside said balloon while the air is rushing out?!
    To me, an ordinary Buyer shouldn't even be doing a leakdown test...that's a test to tell engine-rebuilders where to begin.
    A Buyer should just want good compression numbers from a reliable source.
  12. Rifledriver
    37,252
    Both tests are important. They provide different but overlapping information.
    If I was to do only one it would be a leakdown.
  13. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Leakdown is a more detailed test but requires more effort and is also easy to screw up. If the piston isn't at TDC you might get an inaccurate reading. It's not brain surgery, more like rocket science.
    Just one more reason to pick your mechanic carefully.
  14. Dr.T348
    Dr.T348 Formula 3
    Jan 8, 2004
    1,599
    Chicago NW Burbs
    Richard T.
    I had some screwy #'s as well. From a certified F dealer. Compression in one cylinder of only 110. I took it to my local mechanic, and he said it would not run with compression that low. Who do you trust? The test was repeated at another dealer and #'s were 160's across the board.
    The car has run flawlessly for 2 years, including a rigorous track session.
    If it runs well, drives well I would be careful about putting to much weight into a comp/leakdown test.
