Help with Removing Engine Paint | FerrariChat
Discussion in '308/328' started by Derek250TR, Jun 15, 2009.
  1. Derek250TR
    Derek250TR Karting
    May 7, 2006
    59
    Longmeadow MA
    Derek B
    At some point in the past when the engine in my 308 QV was out, they painted the heads red with a wrinkle paint and they repainted the plenum cover. Most of the paint has flaked off, but there are some spots that I can't just scrap off. I am a little more that hesitant to put any paint remover solvent in my engine bay. My engine is not schduled to be serviced for a while, so waiting for the engine to come out or be taken apart is not a solution. Anyone have any idea of how I can get the rest of the paint off.
  2. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    I'd try an aircraft paint remover. That should be safe for aluminum. I'd do it outside, and use a fan, to keep any explosive fumes too lean for an explosion
  3. Derek250TR
    Derek250TR Karting
    May 7, 2006
    59
    Longmeadow MA
    Derek B
    I have used that stuff on corvette because it supposedly doesn't go through the gel coat. My concern here is not the damage it may cause to the aluminum valve covers. My concern here is starting an engine fire. If there are remenats of the solvent on the engine, after I use it, can it catch fire and burn up the car? I am assuming that all these solvents are alcohal/chemical based and flamable?
  4. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Most paint removers are MEK based, or MEK & Toluene. Both evaporates very quickly. A thin coat will dry completely in a couple of hours, thicker overnight.
    I would expect that you'll be wiping it off so any residue would be extremely thin. Highly unlikely to burn after an hour, probably even after 15-20 minuites.
  5. 308 milano
    308 milano F1 Veteran
    5,350
    Montana
    Kim
    Probably not a good idea to use paint stripper as when you go to wash it off you may end up blowing droplets on painted surfaces and causing a big mess, its hard enough to use that stuff in an "easy to reach" area without trying to do the front bank cover. Take a day and remove the covers and have them media blasted. Alot of work but a job worth doing is worth doing right (and once) If your not up to going this route you probably should wait until next service as I can almost guarantee you will not be happy with the outcome. just my 2cts.
  6. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    I agree, this IS the best way.
  7. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Ditto on the plenum - it's not that tough to remove. You'll be able to do a better job of cleaning these parts (and not risk "unintentionally stripping" other things), and it'll be more enjoyable, if you remove the parts and work on them on the bench.
  8. Derek250TR
    Derek250TR Karting
    May 7, 2006
    59
    Longmeadow MA
    Derek B
    I agree that I probably should wait and take the plenum and valve covers off to strip them despite how tempting it is to use a chemical stripper. However, coming to this conclusion is like getting a seven year old to agree that it is not prudent to eat ice cream for dinner. The forward facing valve cover is out of view so I can wait on that one. Anyone willing to walk me thru taking off the head/valve cover on the rearward side? The plenum doesn't bother me as much as the valve cover, probaly because most of the 308's have the paint comming off the plenum. Anyways, how hard is it to take that off too? Thanks.
  9. phrogs
    phrogs F1 Veteran
    7,358
    Kzoo Michigan
    you see all those little acorn nuts take em off and remove the cover
    go to your local honda dealer and get a tube of honda bond.
    order the replacment gaskets for the valve covers
  10. 308 milano
    5,350
    Montana
    Kim
    #10 308 milano, Jun 17, 2009
    Its a little more involved than that, you will need to unbolt the fuel management system and pull the lines up out of your way so you can remove the rear bank cover, be careful not to kink the plastic lines. I put my new gaskets on and used a fine bead of Hylomar sealant insted of Honda bond, had to go gack the next day and give each acorn nut a 1/4 turn, doesn't leak a drop. As far as removing the Plenum, the best advice I was given was to "loosen all the nuts and then slide a piece of construction paper between the plenum and the manifold, then take all the nuts off and remove the plenum, because there are round spacers than can drop into the manifold when you lift it off and this prevents that from happening" Do a search on the subjects and read as much as you can so there is no suprises, you'll be glad you did.
  11. andy2175m4@yahoo.com
    [email protected] Formula Junior
    Dec 7, 2008
    473
    Los Angeles, CA
    Andy Rein
    You are getting good advice. If you are concerned about the appearance of the valve covers, the only way to do it right is to remove the parts from the engine, strip or bead blast, clean completely and reinstall. The paint stripper will definitely get onto things you don't want stripped and it will leave a mess.
    Also, if you have dual distributors, they should be loosened and pulled out a bit before you lift the cam covers. You will probably rip the distributor gaskets if you don't loosen the distributors first. When I remove the cam covers, I find the gaskets are reusable and don't leak if I am careful.
