Help with restoring dead paint finish | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by paul 308, Nov 10, 2004.
  1. FL 355
    FL 355 Formula 3
    Nov 3, 2002
    1,665
    Ft Laud
    Frank Lipinski
    Good for you Paul! Don't worry about damaging the paint with a random orbital....next to impossible. Yes, use caution when working on corners and on the edge of body panels because paint is always thinner is these areas.
    Peter - Ahh Yes.... P21S is my favorite in the carnauba's and the GEPC is great even by hand. Very well kept secret till now - lol. What you describe is what I use to do and agree with the logic. After polish, 3M IHG and then the top coat of P21S to "lock" the glaze. Works just fine. Only drawback is the P21S is only good for 4-6 washes, then the glaze will be "exposed". However, that is not a real issue if you do a quick coat of P21S once a month or so... the beauty of P21S is that it is so quick and easy to use that I can do my entire car in the same amount of time that it takes to use a Quick Detail spray...great stuff.
  2. FL 355
    FL 355 Formula 3
    Nov 3, 2002
    1,665
    Ft Laud
    Frank Lipinski
    Paul - just as an afterthought...When you get your buffer..
    Place polish on pad, put buffer on car while "off", then turn on the buffer. This will prevent splatter. Start with a speed of 3.5 - 4.0 with moderate to light pressure, let the buffer do the work for you.
    Divide the hood (bonnet) into 4 even sections and begin with one section at a time. I'll use north / south and east/west for reference. When you begin move the buffer north/south..on each pass overlap by about 1/2 the pad diameter to ensure equal coverage. When you finished your first pass on the entire section, now move east/west also overlaping where you just passed. When done, start north/south again. Normally, it will take 3 or 4 of these "sets" to finish a section. Work the product until nearly dry. Wipe off with a towel and inspect the finish. If good, move to next section. If not satisfied, add more product and either increase the speed of the buffer or add slightly more pressure... I prefer speed if I'm not getting enough cut.
    Of course, you can always experiment on your other car first until you get the hang of it, but it is pretty much goof-proof. Nothing can match the look you will get from a buffer and it cuts the time down in half. Good Luck.
  3. paul 308
    paul 308 Karting
    Jan 13, 2004
    110
    Guildford, Surrey UK
    Paul Deslandes
    Frank, thanks for the practical advice which I will certainly use when I get the polisher. I think I'll try it on the wife's Land Rover Freelander first - nice big panels and she won't notice if its not too good as its always covered in mud! If I can get mine looking half as good as your's I shall be delighted.
  4. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    He's quite a character, isn't he? :)
  5. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Check out www.griotsgarage.com/catalog.jsp?&SKU=10625
    and my article at www.fca-se.org/conc_orb.htm
  6. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    My Porter Cable buffer/polisher is manufactured in Germany. Its a "right angle" model with a variable speed trigger plus a multiple position speed dial. I don't use it higher than 3 although it goes much higher. I haven't had much luck with orbital machines when it comes to polishing. It could be that the ones I've used are just low power units though. No matter which method you use, I've seen pros run a piece of masking tape on the edges or the doors, bonnet, etc, - anyplace where you might errantly polish off more paint than you intended. It protects the edges when you polish the remainder of the panel. Once you're ready to concentrate on the edge of the panel you are working on - just remove the tape and get to it.
    Best wishes on getting your 308 finish up to where you want it.
  7. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,699
    NJ
    Peter
    I just ordered the Porter Buffer from the link below. The buffer alone is about $125 from this site, but it doesn't some with the velcro wheel or pads. The set below is $194 including the velcro wheel and 5 pads that are color coded for the various types of use. It doesn't include the glaze pad, so you need another black pad (it's $10). The prices at this site aren't always the best, but the buffer price seems pretty competitive and it's nice to get a package with everything you need.
    http://www.properautocare.com/74uldemawico.html
  8. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,699
    NJ
    Peter
    Frank,
    Thanks for the simple "how to" on the polisher. I'm trying to figure out what GEPC stands for.
    Peter
  9. paul 308
    paul 308 Karting
    Jan 13, 2004
    110
    Paul Deslandes
    Having finally found the time and had a decent spell of weather to get on with trying out the Porter Cable orbital polisher, I'm pleased to report encouraging results with a combination of the polisher and 3M Perfect-it compounds and IHG. Not perfect by any means but a lot better than I would have expected and the return of a certain amount of pride in the appearance of the car.
    Most of the car is done now, apart from the rear deck over the engine and I would like some advice on that.
    1. Is it easier/better/safer to do it on the car or remove it?
    2. How do you get down to the paint between the fins at the ends of the anodised vents. I don't really fancy removing the grills as they are riveted in and I am concerned about damaging the anodising and the deck (mine is a fibre glass bodied car)
    Thanks for all the advice so far and in anticipation of any more that is forthcoming.
    Paul
  10. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Just an FYI, If you have a Lowes in your area, they carry the Porter Cable 7336SP which is the exact same unit as the PC 7424 with a different counter weight so you can use larger pads without offset vibration.
    It sells for about $109.00
    On a side note, be careful with the PC orbital polisher, as they can generate enough heat to move the old lacquer about on the finish of a 308.
