help with testarossa o2 sensors please!!! | FerrariChat
Discussion in 'Technical Q&A' started by bpu699, Sep 23, 2007.
  1. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,513
    wisconsin/chicago
    bo
    Getting ready to put my o2 sensors in, exhaust is back together...
    But I am puzzled, how do you know which sensor goes to which bank???
    The O2 sensors each have a black connector, and then a ground (?) (one is white, one black)...Ok...
    The connectors on the wiring harness appear to be both black??? With the grounds orange???
    How does this mate up???
    Which o2 sensor goes to which bank???
    I looked in the manual, and couldn't find it. Any help appreciated.
    Thanks, Bo
  2. Steve Magnusson
    26,635
    #2 Steve Magnusson, Sep 23, 2007
    The two pin connectors are just a +12V power and a ground for the O2 sensor internal heaters -- it doesn't matter which is connected to which.
    The single wire with the female spade terminal is the active output for each O2 sensor:
    the single wire from the O2 sensor in the 7-12 bank exhaust stream should be connected to pin 8 of the forwardmost injection ECU
    and, likewise
    the single wire from the O2 sensor in the 1-6 bank exhaust stream should be connected to pin 8 of the rearward most injection ECU
    Unplug the 25-pin connectors at the injection ECUs and use an Ohmeter to make sure you've got this correct.
    turbo-joe likes this.
  3. bpu699
    Dec 9, 2003
    17,513
    wisconsin/chicago
    bo
    Thankyou.
  4. Marty
    Marty Karting
    Nov 21, 2003
    108
    Boston/PTown/SW FL
    Martin Stark
    I checked the O2 wire in my '87TR and it was the opposite of what you said. I swapped the O2 connectors and the car wouldn't idle. Are you certain the 1-6 (passenger-side) bank goes to the rearmost ecu?
  5. bpu699
    Dec 9, 2003
    17,513
    wisconsin/chicago
    bo
    I hooked it up as steve recommended, and the cars runs fine...
  6. Marty
    Marty Karting
    Nov 21, 2003
    108
    Boston/PTown/SW FL
    Martin Stark
    My TR must live in a parallel universe.
  7. gabriel
    gabriel Formula 3
    I would like a confirmation of that as well. I suppose it is possible that the wires were mixed up and the CIS was adjusted to fit, I suppose.
    Is it so that the car will not idle correctly if the O2 sensors are mixed up?
    Should the battery be disconnected then reconnected? - Steve?
  8. Steve Magnusson
    26,635
    Fairly certain, but two points:
    1. Let's confirm whos' who -- by "forwardmost" I mean the one physically mounted the furthest forward on the chassis (not the one closest to you when you stand at the back of the car). If we're not in disagreement there,
    2. As long as the O2 sensor, Airflow Meter Potentiometer, and EHA from the same bank are hooked up to the same injection ECU, it wouldn't know the difference (I'm not sure if this is, or isn't, physically possible with the harnesses). For the "stock" arrangement, the two wires going to each EHA on the FD would be the following colors:
    1/6 bank = yellow and yellow with black
    7/12 bank = grey and grey with black
    Are yours reversed from that?
  9. Marty
    Marty Karting
    Nov 21, 2003
    108
    Boston/PTown/SW FL
    Martin Stark
    I'll check in the morning.
  10. Steve Magnusson
    26,635
    Yes, this would be bad for warm idle (closed loop) -- for cold idle (open loop), it wouldn't make any difference.
    No difference, the TR injection ECUs aren't that "smart" and have no "memory".
  11. Llenroc
    Llenroc F1 Veteran
    5,459
    Colorado
    Vern
    I was under the impression if you reversed the O2 plugs the engine won't run properly ie; one side runs lean the other rich. The ECUs aren't sync'd to the O2 readings.
  12. bpu699
    Dec 9, 2003
    17,513
    wisconsin/chicago
    bo
    If that were done, wouldn't it be obvious by looking at the exhaust? Wouldn't one side be emmitting gray smoke/haze?
  13. Marty
    Marty Karting
    Nov 21, 2003
    108
    Boston/PTown/SW FL
    Martin Stark
    I spoke a little too soon. Checking the color code to the EHA's is not easily accomplished.
  14. gabriel
    gabriel Formula 3
    You got that right. I think you need to remove the upper intake to do it, else I don't see how you could ever work back there.
  15. Steve Magnusson
    26,635
    You guys are making this way too hard. Open the rear bonnet and look in from the RH side around the cyl #1 intake runner -- you should be able to tell if the wires going to the 1-6 FD EHA are light (yellow) or dark (gray).
  16. gabriel
    gabriel Formula 3
    Yep. There was some tape on the wires, but Steve is right again. :) Yellow.
