Help with this Air Corrector jet | FerrariChat
Discussion in 'Technical Q&A' started by Corsa308, Sep 1, 2007.
  1. Corsa308
    Corsa308 Formula Junior
    Apr 22, 2007
    290
    Sydney, Australia
    Steve D
    Any ideas what size jet this is?
    If I was to guess it would be 770, but most of the discussions are around 220.
    Are they just strange looking 2's?
    The zero at closer inspection isn't even closed and is open at the bottom.
    What do you reckon?
  2. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,828
    Cerritos, CA.
    That's way too big
  3. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    I would think it's a 170. If you've got a good collection of twist drills put different size drills in the hole (not the pointy end of the drills!). When you find one that has a good fit measure the drill diameter with a caliper. Should be 1.70mm for a 170 jet (if that's what it is). Someone may have drilled the jet larger in the past so this really is a better method than going by what is stamped on a jet anyway.
  4. bill308
    bill308 Formula 3 Silver Subscribed
    May 13, 2001
    1,225
    Windsor, CT
    Bill Sebestyen
    I agree with Eric. It's likely a 0.170 mm jet. Does the hole appear to be the same as it's cousins?
    Bill
  5. Corsa308
    Apr 22, 2007
    290
    Sydney, Australia
    Steve D
    I'll measure it against a drill stem and see what I can determine.
  6. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    1.70mm (0.170mm would be awfully small!)
    Erich
  7. bill308
    May 13, 2001
    1,225
    Windsor, CT
    Bill Sebestyen
    Eric,
    Yep. Too much red wine on my part. My post should have shown 1.7 mm.
    Bill
  8. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Hopefully it's Italian. Must be good wine... you spelled my name wrong twice ;-) (Erich with an "h" is the German spelling)
