Hello I am a new memeber from Mexico City, i am having problems with my 2000 F360 F1, yesterday the gearbox not function any more. Once i started the engine a red light in the dash blinks and i can't apply any gear. I will apreciate your help. Regards
Hello Matteo, Can i contact you by e mail or telephone. i want to know if can order the clutch from you. Regards
Have you tried the Ferrari-Maserati dealer in Mexico City (at Presidente Masaryk) ? I'm sure they will be able to help you.
I got and replyed to your e-mail. Like I said in the e-mail. I would recommend a local (to you) Ferrari shop to get your parts and do the work.
Before you start throwing expensive parts at the car the red light indicates 2 things. 1, some thing has gone wrong that is serious enough that the computer is preventing you from driving the car. 2 it is recorded in memory so that it can be diagnosed and repaired properly. Take it to your dealer and have it fixed. With out the proper equipment (SD2) you cannot replace the clutch without encountering problems anyway so buying a clutch will do you no good.
Autodynamica, The red light blinking is actually a code. If it is a steady blinking, then the starter fluid pump is broken and will be need to be replaced. If it is one long blink followed by three short blinks, then both the starter fluid pump and the actuator will need to be replaced. Damn Ferrari for putting electro-hydraulic starters in the new cars.
